Old 01-28-2003, 06:16 PM
4GB16aDX 4GB16aDX is offline
Send a message via AIM to 4GB16aDX
Shaking at a stop and a few other things?
Whenever i drive my car now some weird stuff happens when ever i hit the brakes and come to a stop. My car starts shaking really bad. It is annoying as all hell too cause the sound just eco's inside the hatch. I have a feeling that i might be having problems with my torque converter but i am not sure. Also..........whenever i don't run the car for a few days and take it out(mind u it is around feezing where i live) and i step on the gas to accelerate it periodically will not accelerate and it is like my engine almost shuts off? Nothing comes out of the exhaust? This can be scary sh*t when merging..........anyone got any ideas??
4G Baby!
Old 01-28-2003, 07:10 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I'd check your brakes, that may be the vibration your feeling....or maybe your tires? As far as your car freezing and not accelerating...i dont know...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 01-28-2003, 08:23 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
have you checked the ecu codes yet?
This is the real melt pizzle
Old 01-28-2003, 09:07 PM
its not my ecu codes, i will check out the brakes but i don't think that is the problem
4G Baby!
Old 01-28-2003, 10:41 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
does your pedal move up and down with the shaking? If it does then the problem is most likely warped rotors. About the acceleration, it sounds like something fuel related to me but still not sure. pull the spark plugs real quick and check to see if their fouled up or anything.
Old 01-29-2003, 03:16 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
the shaking under braking could be the track rod ends coz my friend had the exac same thing on his Vauxhall
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 01-29-2003, 10:36 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Shaking under braking can be an umber of things. The most common being worn/warped rotors with worn brake pads. So that would be the first place I would check. On a more difficult note, it could be anything else on the hub. Worn wheel bearing, tie rods, ball joints, shocks, etc. So, do you know if it happens more on one side, or both sides are pretty much equal?
Old 01-29-2003, 03:37 PM
Both sides are pretty much equal, it might be my brakes but i mean i just got new brakes put on 4 months ago....i think the paused acceleration is most likely fuel line freez. Anyone know of any ways to fix that?
4G Baby!
Old 01-29-2003, 04:34 PM
Dweezil6969 Dweezil6969 is offline
as fer as the acceleration when cold it sound like a fule problem. try dooing so maintaince if you haven't in a while. mine did the same thing untill i replaced the pcv valve and the hose.
`91 CRX DX Kind of moves
`90 CRX Si
Can also be found on:
XceedSpeed.com, MichiganCivics.com, and Zilvia.net
Old 01-29-2003, 09:14 PM
seth 90DX/ZC seth 90DX/ZC is offline
Banned
The same shit happens to me when I brake... Stock DX Discs cant take the abuse, mine are warped like hanable lector... Not to expensive for cross drilled rotors thoe, its those four piston calipers that will bite you in the ass! BTW if anyone knows of any good four piston (or good two piston) calipers that arent taxed as fuck let me know!
Old 01-29-2003, 09:18 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
I would reccomend getting the Brembo blanks for $17 a rotor. They last a while, they can take a beating and cheap for only $17 a rotor.
Old 01-30-2003, 02:53 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
one time my rotors were so warped that it shattered my brake pads
DIC not working properly, a few other things AspenSTi Grand Prix 2 12-07-2009 04:15 PM
96 explorer hatch problem + a few other things me-and-em-too Explorer | Explorer Sport Trac 2 07-13-2006 12:20 PM
Tachometer/Speedometer...and a few other things 96aurora Aurora 11 05-05-2005 04:06 PM
Vtec not working and some other things, someone help! atrain598 Engineering/ Technical 1 10-28-2003 04:11 PM
question about Boxster and some other things BigBlock454 Street Racing 21 03-16-2002 02:29 PM
