Old 01-27-2003, 11:48 AM
bdstbtch's Avatar
bdstbtch bdstbtch is offline
Send a message via AIM to bdstbtch Send a message via Yahoo to bdstbtch
Another Problem
ok...now my car won't stay started. I turn the key to start it and it starts up, but as soon as I let go of the key it dies. but when I give it gas while starting it, it starts. It only does it when it's cold. Does this mean that my key and tumbler needs replacing or possibly my injectors are clogged. I dunno. I would apprieciate suggestions.
Thanks!
~ Cherylyn ~
Old 01-27-2003, 11:55 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
pull up the carpet under your glovebox on the floorboad. you'll see a metal box with a L.E.D. that is your ECU. check for trouble codes. turn your key one click in the ignition and watch the L.E.D. for flashes. there should be 1 flash to let you know it's working, a pause, and then a series of flashes. count the flashes. then refer to the f.a.q./ecu error codes page.
it could be a lot of different things. ecu error codes will help find the "needle in the hay stack"
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-27-2003, 12:11 PM
bdstbtch's Avatar
Yeah...I was going to check the codes tonight...I haven't had time to do it yet...so I just though other people might have had this same problem.
Thanks though!!!
~ Cherylyn ~
Old 01-27-2003, 12:14 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Ok when u cranked it up the second time did it stay on? Cause i'm goin through that now. If i drive my car for the first time today and i start it once it dies. Second its ok. ITs normal in the winter.
Old 01-27-2003, 12:31 PM
bdstbtch's Avatar
it won't stay started unless I push on the gas.
~ Cherylyn ~
Old 01-27-2003, 12:40 PM
91civicDXdude's Avatar
I had the exact same problem.... turn the car over for the first time in a couple of hours and it would start, and then die. I replaced my injectors and it has never done it since.
Old 01-27-2003, 12:58 PM
mellowboy's Avatar
yeh just check your ecu codes. It could be a bad sensor.
Old 01-27-2003, 02:19 PM
bdstbtch's Avatar
Well...I just checked my ECU and it's not throwing any codes at all...
~ Cherylyn ~
Old 01-27-2003, 02:42 PM
mellowboy's Avatar
Must be ignition problem or fuel injectors.
Old 01-27-2003, 02:46 PM
bdstbtch's Avatar
wouldn't it be throwing a code 16 if it were the injectors???
I'm wondering if it's just all gunked up, so I'm going to get some cleaner stuff and see what happens then...
My ex had a CRX that this problem happened to, but when he pushed in the accelerator it still didn't start, and he had to replace his key and tumbler... but I can get mine to start...I just don't want to have a long going problem.
~ Cherylyn ~
Old 01-27-2003, 03:24 PM
mellowboy's Avatar
don't buy those bottle cleaners. They don't work. Take them to a mechanic to get them cleaned. Try replacing your coil and rotor for your distributor also.
Old 01-27-2003, 03:33 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Sounds like bad distributor cap and rotor to me.
Old 01-27-2003, 05:32 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Well, as long as the key turns, it's not the lock cylindar, so you don't have to worry about that...
If it's anything to do with the ignition switch, it's most likely just the switch itself which bolts onto the back of the lock... But it doesn't sound like that's the problem at all.
I would also check your Main Relay, because I know those have a tendency to flake out and cause problems with starting the car...
Old 01-27-2003, 05:39 PM
siblue99 siblue99 is offline
Send a message via Yahoo to siblue99
Just fixed the same problem its probably the ignition switch behind the key cylinder.......pretty cheap from a junk yard....cuppla bucks.
06 performance white
90 LX Hatch 5.0 swap
