Old 01-27-2003, 03:11 AM
impreza2k2's Avatar
impreza2k2 impreza2k2 is offline
Lightbulb I need some advise
I'm currently trying to build a cooper s and have come to a problem on making the hood scoop(air inlet). I had already drill the holes, but i am confused on making that thing... any suggestion?
Don
Current project:
Mini Cooper S, 350Z, Nismo R34GTR, Atlezza, Miata
Old 01-27-2003, 03:17 AM
bigfrit's Avatar
bigfrit bigfrit is offline
I m not that great modeler, but I found out that if you have already the basic holes and you want to make an even wide gap of it, like the intake, just take some 400-grit or so sandpaper and roll it like it makes a quite hard tube that fits in the hole and gently push and pull it out of the gap untill you have the perfect round shape .
as for the contour of the scoop, I don't know, maybe try to put a panel line around it by using an x-acto knife, first very getly then scribing along the lines...
Hope this info is of any use, and if not, feel free to correct
ciaoo olivier
Old 01-27-2003, 03:18 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Can you post a pic of the kit showing the bonnet
Steve a.k.a. Hiroboy
Old 01-27-2003, 03:31 AM
impreza2k2's Avatar
Thanks!
here is the photo of the holes
Don
Current project:
Old 01-27-2003, 03:42 AM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
I just built that kit a couple weeks ago, and since it didn't come with the hole for it, I didn't make one......
but yeah, try using sand paper or a file to make it
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 01-27-2003, 04:21 AM
hirofkd's Avatar
hirofkd hirofkd is offline
The hood of the S is a little sticking out, compared to the normal one.
Print the b/w image of the photo above in 1/24 scale, and use tracing paper to transfer the intake pattern to a plastic sheet of approximately 1 mm. That way, you can cut the opening and scribe the surrounding line easily.
Then, cut it out like this...
..., and sand the sides to make the edges a little thinner.
Bend the part with fingers, and glue it on the hood, and fill the gap with putty or super glue.
Then, sand to blend the added piece to the hood.
Hand paint the primer, and sand, so that you can check if the piece is blended smoothly.
Hiroaki Fukuda
Old 01-27-2003, 11:39 PM
impreza2k2's Avatar
Thanks hirofkd, but i'm still confused
Here is what i have done so far.
Is this the way u mean to do it? or..
Rear
Don
Current project:
Old 01-27-2003, 11:53 PM
64 Chevy 64 Chevy is offline
another idea for sanding the inside, you may want ot try a nail file, the kind with sandpaper on each side not the metal kind.
Why can't I think of any thing clever to put down here?
Old 01-28-2003, 12:56 AM
hirofkd's Avatar
Almost!
But it appears to me that the plate is attached a little too tilted, but you got the idea right.
What I meant was like this.
You'll probably need more reference photos, especially from the side.
This one shows the hood well, and the image is big enough.
http://www.velocityphotos.com/images...oopers4901.jpg
When modifying a body, it helps if you try to picture the apex or sides of the carve. In this example, you can break down into this.
Red is very simple. Pink is slightly more sides to reduce the amount of filing work.
After determining the flat plane, you have two choices.
Addition: Glue minimum size of plastic sheets, and fill the gaps with putty.
Subtraction: Glue relatively thick plastic sheets, and file and sand to the desired shape. (, which I suggested.)
There's no right answer to this, and it takes some practice to fine your own style, but certainly it's not that difficult.
Good luck.
Hiroaki Fukuda
Old 01-28-2003, 01:57 AM
impreza2k2's Avatar
Thanks again, i kinda get it this time the pic u draw really help.
i'll post some pic once i get the shape of the scoop done and let u see what i can mod from it.
Don
Current project:
Old 01-28-2003, 02:11 AM
bigfrit's Avatar
IOh, and also notice when building this kit, it hasn't got brake disks, so you would have to add them.
Ciaoo Oli
