Go Back   Automotive Forums Car Chat > Racing > Initial D
Initial D Japanese Cartoon Racing, Drifting and more.
Old 01-21-2003, 10:04 PM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
Gran Dorifto 2!
http://www.gtplanet.net/gallery/phot...andorifto2.avi
Thanks for the link, NSX
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 01-22-2003, 07:05 PM
NSX's Avatar
NSX NSX is offline
Send a message via ICQ to NSX Send a message via AIM to NSX Send a message via MSN to NSX Send a message via Yahoo to NSX
hehee
its cool stuff; I'd try but I simply don't have the time.
Old 01-23-2003, 09:42 PM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
Its really easy. It only took me a couple hours to drift like the ones in the videos.
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
Old 01-24-2003, 07:47 AM
Monkey-Magic-S15-R's Avatar
Monkey-Magic-S15-R Monkey-Magic-S15-R is offline
Banned
what settings are good for drift in Gran tourismo?
Old 01-24-2003, 06:00 PM
NSX's Avatar
NSX NSX is offline
Heres some sites:
http://www.gtplanet.net/forum/t-14272.html
From GTPlanet.net
THE FINAL SECTION OF THE ULITIMATE DRIFT GUIDE
POWER OVER
"power over" is japlish for power oversteer. If your car has pleanty of horse power, simply plant the throttle on the exit of the corner to create wheelspin. Dont try this on the entry of the apex as it induces understeer.
Best suited for-FR or MR but the gt-r v-spec2 is mad.
Thats most of the drifts i can think of right now but a Im shure that you'l all find your own way to drift.
Just for Begginer tuners I'll Give you a few tips for making a good DRIFTA , if your cash straped the best idea is a silvia with Sports brake balance controler, lightwieght flyweel and triple clutch. A Stage 1 0r 2 turbo if you can affort it. Also sim tires are good for drifting
As you aqquire more money buy the full suspension and the power upgardes so the h.p is between 300 and 400.
Settings.
sr-5.8/7.8
rh-100/104
bnd-5/7
rbnd-6/7
cmbr-3.0/0.3
toe-0.5/1.5
stabs-3/4
brakes-6/25
lsd
50
50
20
gears level 26
2.890
2.100
1.700
1.300
1.150
0.975
fnl-3.989
also you might want to change yor tcs to low or of.
good luck and happy drifting.
P.S The calsonic skyline is great for drifting.
Old 01-26-2003, 07:29 PM
Cbass's Avatar
S15. Stock suspension, sim tires, and LSD diff set to a really high decceleration number.
There are a lot of good guides out there, just do a search for "Gran Turismo Drifting" on google...
Old 01-28-2003, 07:24 PM
Amish_kid's Avatar
Amish_kid Amish_kid is offline
any setting for any car
there is a little bit for the drift in there you just have to read some of the reviews
Tuner Vault
Old 01-29-2003, 06:38 PM
Cbass's Avatar
Easiest way to drift, is to go for a 50/50 balance in EVERYTHING. Now, if you start with a car that doesn't have a 50/50 balance in weight distribution, this makes things trickier.
Good rule of thumb are the spring rates, start with even front and rear spring rates, and if the back end doesn't come around once you get off the brakes, then you should increase it a little.
Decrease the front camber by 1 degree or so, this makes for better turnin. Use sim tires, and only go to stage 2 weight reduction. Stage 3 alters the physics of how the car grips too much, and a racing modification completely changes the handling of the car.
Old 01-30-2003, 05:03 AM
Banned
tanks for teh tips
Old 01-30-2003, 06:25 PM
Amish_kid's Avatar
id say best car to learn on in my opinion would be the Supra get one mod the hell out of it usually end up at 1072 hp then get full custom supension make it a little stiffer than normal and turn off TCS and ASM and just mash the gas and cut the wheels and you on the way to a drift
Old 01-30-2003, 06:45 PM
Banned
there's a difference between drift and outta control
Old 01-30-2003, 08:09 PM
Its also best to practice on a course with BANKED TURNS.
My suggestion: buy a z32 tt, stiffen the suspension, install simulation tires, set traction control and active yaw control to 0 and head out to midway field :ylsuper
Isitcontagious.com
'92 S13 coupe
Cone Filter
Next up: LSD
RIP #05
Old 01-30-2003, 09:02 PM
NSX's Avatar
NSX NSX is offline
Originally posted by Fliquer
buy a z32 tt
What's a z32?
Old 01-31-2003, 12:57 PM
Amish_kid's Avatar
Originally posted by NSX
What's a z32?
Nissan 300ZX TT
Supra Would Be Better For Starting To Drift:o
Old 01-31-2003, 04:10 PM
NSX's Avatar
NSX NSX is offline
Here's another site:
Drift Guide @ GranTurismo.com Forums
1973 Ford Gran Torino Help sidaroni2320 General Discussion 2 06-18-2009 08:17 PM
POSSESSED WIPERS!! 94 Regal Gran Sport bs009 Regal 2 06-12-2009 04:03 PM
Richmond, Virginia Dorifto Day! KoreanBoost 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 03-23-2004 10:48 PM
Dorifto time! FR_Madness Introductions 0 03-16-2004 03:00 PM
Super Dorifto Rally Results CanadianGTR 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 11-06-2003 09:56 PM
