Old 01-21-2003, 04:46 PM
90hbvtec's Avatar
90hbvtec 90hbvtec is offline
clutch riding
does anyone know if its clutch riding.. if i hold on the clutch while waiting for the green light..?..is it like burning out my clutch or what...
tru sohc vtec......
d16z6,ractive intake,ractive wires,msd ignition system w/blaster2
obx headers,pacesetter catback, w/test pipe,arospeed bomb muffler,tockico illumina shocks,r1 coilovers,GSR blades rims,ebay short shifter, w/neuspeed bushings,neuspeed strut bars front n back,ingalls camber kits altezza lights,indiglo gauges,proform shift light,integra center console..thats it for now...what else do i need...??ummmmmmm..TURBO..!!!!
Old 01-21-2003, 05:19 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
I dunno, generally I chill in neutral with the clutch out at lights and shit, and I also neutral on the way up to a stop sign or red light, just the way I have always drove stick.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 01-21-2003, 05:57 PM
GTA's Avatar
GTA GTA is offline
Whee..
thats the same way i do it.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 01-21-2003, 06:55 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Thats how i drive mine too.....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 01-21-2003, 07:13 PM
91BLKsi 91BLKsi is offline
Send a message via AIM to 91BLKsi
me too!
Old 01-21-2003, 07:31 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
I wait at the light with my foot on the clutch, and i have heard that its bad for your throw out bearing......
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 01-21-2003, 07:37 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
i thought riding the clutch was where u keep ur foot on it and have it slightly engaged when your driving, think that makes sence, or like out when u normally drive but still have it in just a bit... anyone out there understand what i just said? i hope so.
all i know is when i was driving before i started working on it i put it in neutral and just hit the brakes to stop instead of down shifting then sit in neutral at lights and stuff or traffic
Old 01-22-2003, 02:12 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
ya i think its when u just rest ur foot on the clutch pedal while driving.
i downshift and let the car slow me down along with the brakes till i almost stop then put the clutch in when i pull up to a red light, then let it chill in neutral
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 01-22-2003, 02:16 AM
90hbvtec's Avatar
yeah..cause i dont know if im buring my clutch if i hold down the clutch too long...so yeah....
tru sohc vtec......
Old 01-22-2003, 02:20 AM
H4Bangin's Avatar
just by holding it in isnt hard on the clutch, i Think it just wears the pressure plate spring tension..... i think, thats what i have herd
Old 01-22-2003, 02:24 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yes i understand and your rite. Having a clutch not in all the way and pressing the gas pedal while moving your is riding your clutch. Dont try to do it and dont' ever do it.
Old 01-22-2003, 02:28 AM
H4Bangin's Avatar
ya thats rite now i remember
Old 01-22-2003, 10:39 AM
darolh darolh is offline
Unless you're using the clutch to get going or change gears keep your foot off the pedal. Resting your foot on it can prematurely cause throwout bearing failure. Holding the car in position by slipping the clutch will prematurely wear the clutch and glaze the disk. It can also crack flywheels and crack or warp pressure plates.
It's OK to sit at the light with the clutch depressed completely. If I'm gonna be there a while I usually go to neutral however just before the light changes pop it in gear.
If you want to hold the car on a hill learn to "heal and toe" or use the handbrake.
It's a good idea also to learn to drive your car without the clutch. If your cable fails or the disk gets stuck you may need to keep going.
Old 01-22-2003, 02:35 PM
Melt's Avatar
Previous owner of my car must have done this, we had to replace pressure plates and retune the clutch cause it was slipping.
AF Bay Area Crew
Old 01-22-2003, 02:57 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Interesting thread.
Riding the clutch = Holding the clutch partialy out. Its generaly not good for it, as it creats excessive wear and just plain smells bad.
Slipping the clutch = Releasing the clutch slowely. Not good to do it often or for a long period of time as it has a similar effect to riding the clutch. However its often the only way to get a smooth start on a steep hill, or when racing off the line.
Dumping the clutch = Taking your foot off it as fast as you can. Not a good idea from a standing start, or when making fast violent up or down changes. Ok occasionaly, but do it to often you start stressing things in the drive line and engine.
Holding the clutch in = or sitting at a set of lights with the car in gear and your foot on the clutch should be kept to an absolute minimum.
Its puts excess load and heat into the Thrust/Throwout bearing, and cause it fail prematurly. (especialy if it wasnt properly lubricated when installed, or is getting old).
You should only do this when your getting ready to move off, say when pulling out of a side street, or at a set of lights where you know the phases, or at the frount of a set of lights where you don't know the phases.
Otherwise if your in Traffic when the light goes green you have more than enough time to get the car in gear before the car in frount starts moving. (if you can't then you need more practice)
I also noted someone mentioned throwing the car in neutral to slow down.
Don't.
Change down throuh the gears as you slow down, its better for the car and gearbox, and it means your ready to move off should the light change, or something happens in frount of you requiring you to have total control of the car. (e.g. dodge to the side etc)
And when changing into reverse due to the design of Honda G/boxs its always a good idea to select a forward gear first, then go straight into reverse. It stops the layshaft from spinning, which if often the cause of a grunch when putting the car in reverse.
89 clutch replace? Hard? auto89 Pick-Up 0 03-04-2010 06:18 PM
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 12:17 PM
03 Ride Height Problem - 03 Silverado 1500 z71, 5.3L tallroach85 Silverado 2 04-03-2009 10:30 AM
Installing a clutch pedal assembly towelie Ranger | Courier 1 02-15-2009 07:18 PM
