Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-20-2003, 11:51 PM
iT90accord iT90accord is offline
Send a message via AIM to iT90accord Send a message via Yahoo to iT90accord
Turbo or swap i cant decide????
I have a 92 prelude si w/ a h23a non vtec i have been thinking about swapping it out with a h22a siR motor and adding a couple perf. parts to it exhaust, headers, etc... or building up the h23 with new internals pistons rods cam shaft blueprint balance bore and all that fun shit and then puttin a turbo on it. I'd like to put a t4 turbo on there if possible. i dont really know a hell of a lot about turbos though so if you guys could help me out with the pro's and con's and which one would generate more power. Also my engine right now has around 100,000 miles on it but would it be ok if i redid the internals and everything or would that be a problem cause i want it to last a while. I've looked around for some turbo kits but cant really find any good ones except for fmax but its like 3,600 bucks so i'd guess i'd have to go with a custom turbo setup. Anyways just give me the suggestions or any other info that would help! thanx
Live today like your dead tomorrow
02 Black WRX
17" Rota Gold Rims
HKS EBC
Blitz Nur Spec Exhaust
Tinted Headlights
More to come...
Old 01-21-2003, 01:36 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
You mentioned a couple options here. You could rebuild and then turbo the current motor or swap for an h22a and keep it NA. If you did the rebuild, the mileage won't really matter much. BUT if you decide not to do the rebuild, or that you can't afford it, I'd say don't waste your time and money on a turbo setup for a motor that old with that many miles on it. Instead I'd do the swap. But if you can afford it, the rebuilt h23 with a turbo would have the potential to outpower an NA h22a by a long shot. You could definately go with a custom turbo setup as well. Also, I don't know if a T4 would be the best option, but that's definately something that can be decided later on down the road, when you decide what you're going to do and how much power you plan on making. If you haven't noticed by now, most of this depends completely on how much money you plan on dumping into it
There's no replacement for displacement...No, not even a turbo.
Old 01-21-2003, 08:57 PM
Well i wouldn't put a turbo on the current engine without beefing it up and i'd like to spend less than what a swap would cost plus i have a friend who could do all the stuff to the engine which would save me some money and he might be able to put on the turbo to but i dont know about that yet. I'd really like to go with the turbo because i've heard the h23 is a good engine for that since its got lower compression and its more torqueE (cant spell it lol)
02 Black WRX
17" Rota Gold Rims
HKS EBC
Tinted Headlights
More to come...
Old 01-22-2003, 05:31 AM
hybridsol's Avatar
hybridsol hybridsol is offline
Send a message via AIM to hybridsol
Re: Turbo or swap i cant decide????
Keep the h23a1 and rework the internals, as for turbo kits I'd look into a drag gen 3 which utilizes a T04/T3 turbocharger. But I'd keep the h23, 100,000 is just breaking it in. (highly tunable motor)
Old 01-22-2003, 08:32 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
i say go turbo!
there is alot more posibilities with a turbo car,
also if maintained properly a turbo car can also be very reliable as long as u dont abuse the car!
btw what did u want to know about turbos?
i can try 2 help if i can!
good luck!
1
Shift_BOOST
97 s14
Old 01-22-2003, 10:26 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I say swap then turbo, that is unless that isn't in your buget range. If not, I would say go turbo and build up your current engine. It would be better to swap then turbo in the long run though, JMO.
Old 01-22-2003, 05:36 PM
hybridsol's Avatar
actually the strongest motor combo would be a h23 block w/ h22 head and turbo. (very similar to the frankenstien B-series mix) But I assume you mean one motor or the other. In this case h23a1 will prove to be a more cost efficent turbo build. By means of turbo choices Garret turbo is a good choice. I'd probably go with a T3 or buy the drag gen 3 kit if you don't wanna piece one together. OK the size of the turbo will dictate its boost production. This is complicated further by altering the sizes of the turbine, or the compressor. If the turbine housing has small apertures, it will make the turbo work at low engine speeds, but cause a restriction to the exhaust gasses at high RPM. If the compressor assembly is too big in relation to the turbine, it could cause stalling, and if it is too small, it could cause the turbo to over speed and blow. (h23/h22 combo less lag with a smaller turbo is the way to go.)
Old 01-22-2003, 11:08 PM
Well i know about all the main parts of a turbo but i dont know much about all the fuel shit and all the little parts that make a difference. And like what companies make the good products for a turbo and what all i would need to make a custom setup. So if you could give me a little info on the little shit and what all goes into the turbo that would help a lot. If you know any sites to help me out post those too.
THANX
02 Black WRX
17" Rota Gold Rims
HKS EBC
Tinted Headlights
More to come...
Old 01-23-2003, 09:02 PM
SleeperCivic SleeperCivic is offline
Wow! What a salesman! It's the old question again: swap or turbo? I'm sure that if you hit the "Search" link, you can find so many posts with this very same subject title (if the links come up!). Enjoy!
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
Old 01-25-2003, 06:16 PM
Well i found somebody with a custom turbo kit from rev hard its got a t4 turbo and he said on his engine that he had fully built he got 600+ hp i dont know about 600 hp though. that should be on its way in a week or 2. I need to find a crankshaft, some cams, titanium retainers. I found rods, pistons, pistons, somethin else im probably leavin out but if anybody knows where i can get any of that stuff let me know.
thanx
02 Black WRX
17" Rota Gold Rims
HKS EBC
Tinted Headlights
More to come...
Old 01-25-2003, 06:17 PM
O also somethin else i found a place that does a h22a engine swap that installs it tranny and everything for 3500 bucks which i think is pretty damn good cause the cheapest quote i ever got was 6000 fuckin bucks.
02 Black WRX
17" Rota Gold Rims
HKS EBC
Tinted Headlights
More to come...
Old 01-25-2003, 06:52 PM
hybridsol's Avatar
thanx
680.9 Hp and 496.6 Lbs. of torque at the wheels, 20 PSI of boost.
H23 block with JE pistons, Saenz rods, JG Pro Series big valve head, Motec M4 Pro with 1600cc injectors, and XS engineering turbocharger.
Old 01-26-2003, 04:21 PM
Tha't what I'm talking about. Pure meaness.....
Old 01-27-2003, 06:25 PM
i was wondering if anyone knew if the h22a rods would fit in the h23a motor?
02 Black WRX
17" Rota Gold Rims
HKS EBC
Tinted Headlights
More to come...
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
