Old 01-20-2003, 06:49 AM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
Car revs by itself
88 Accord LXi revs by itself when it's at idle. Revs between 1250 to 1450 RPMs I think and then drops back down and does it over and over, and it's annoying. I just put a short ram intake on a few months ago and it didn't start until about a month ago. My cousin's 5th gen civic just started doing it right after she put her exhaust on a few weeks ago also. Anyone know what's wrong?
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 01-20-2003, 01:06 PM
J_Spec_NiTeMaRe's Avatar
J_Spec_NiTeMaRe J_Spec_NiTeMaRe is offline
Send a message via AIM to J_Spec_NiTeMaRe
lol alot of cars do that. it could be 2 things that i can think of. the first, your car is cold, and your ecu is just trying to keep enough revs until your oil is warm and viscuous enough to maintain a steady idle without dying. the other thing could be that since you modified the way your car gets air/relases exhaust, your air/fuel ratio is not stock anymore. therefore, your car might have a hard time maintaining a perfect idle because its getting more air than its programmed for, and has to compensate by varying your revs automatically to maintian a balanced air/fuel ratio.
in any case, im pretty sure that your car shouldnt do that. im not a mechanic or anything, so i would get a professional opinion.
Old 01-21-2003, 01:55 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Check your sensor...Throwing a service light? Make sure there are no leaks in the intake track
There's no replacement for displacement...No, not even a turbo.
Old 01-21-2003, 08:40 AM
hybridsol's Avatar
hybridsol hybridsol is offline
Send a message via AIM to hybridsol
I dealt with this problem about a month ago, on a friends girlfriends car. First of all check your breather hose for blockage/breaks ect. Second check your intake to see if there's fluid laying in it, if there is clean it out thoroughly, Open the butterfly and spray with I. cleaner. Also see if the ecu is throwing codes.
Old 01-22-2003, 01:03 AM
neunan neunan is offline
Send a message via AIM to neunan
that happened about a week ago to my friends 3000gt after he replaced the clutch reservoir. turns out his air sensor was just unplugged.
96 Accord EX 5spd coupe - black
AEM cai * DC Sports cc 4-2-1 header * GReddy EVO catback* AEM trupower pullies * ACT HDSS clutch kit * ClutchMasters 8lb flywheel * NGK blue wires * 4 wheel Brembo slotted rotors with AEM pads * 4bidden Motorsports shortshifter
pioneer deh9300 * phoenix gold zero point wiring * blaupunkt pa2100 pushing diamond audio HEX 6.5 comps in front * blaupunkt pa275 pushing power acoustik fahrenheit 6x9s in back* 5" LCD TV * 8-bit original NES
Old 01-22-2003, 10:00 AM
shepworldwide's Avatar
shepworldwide shepworldwide is offline
lol.. looks like the honda goblins got to you..
infamous problem, this has to every honda/acura i've ever owned and i could never fix it.
hi hb/sol heard about the big win!
:twoguns:"shepworldwide":twoguns:
96 integra for sale or trade
huge northest meet may 31st. come check it out.
Old 01-22-2003, 06:06 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Mine did that from 1000 to 4000 all the time. My neighbor is a mechanic at the Honda dealership and he helped me fix it. Behind my intake manifold/throttle body is an idle control sensor. Keep is mind this is a B-series and I'm not positive about yours. Anyways there is this plastic screw thing that is spring loaded in the housing of the sensor. Vibration tends to back this out causing a internal vacuum leak. You need a mirror so see in there unless you take off the intake manifold. Its a bitch to get back there and thread it back in but I did and screwed it all the way in and the idle went right back to normal. My neighbor said this is a very common Honda problem and he sees it about twice a week in the shop. About two months later it idled ireg. just a little and I had a vacuum line leaking which I replaced and it fixed it again. Maybe this could be it but what other people suggested could be the problem too. A bad sensor would definatley cause that. Have your ECU checked out too.
Old 01-22-2003, 07:17 PM
V00D00 V00D00 is offline
hehe damn Ghosts reving your engine!
Old 01-25-2003, 10:26 PM
Took it to honda last week and they foung a hose leak, replaced that and it's fixed, thanx though guys.
2000 BMW 323IT
1954 Ford F100
