Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 01-19-2003, 10:57 PM
Tony&Delfina Tony&Delfina is offline
Question 1986 ford tempo (no spark)-sudden loss of power
We have a 1986 Ford Tempo with 320,000km on it with a carburetor (not fuel injected). No doubt it has been reliable until now. During the last month we have been experiencing a sudden loss of power (no spark). We always had the usual problem with it overfueling (stalling) at stoplights and such, but this is new. We have replaced the ignition coil, spark plug wires and finally the ignition switch. The spark plugs show a good clean spark when the car is running. The car battery is 3 years old and appears to be showing no problems. After the ignition switch replacement we thought we had it solved. For one week during a recent cold snap of weather no problem surfaced. As soon as warmer weather arrived the problem returned. We thought it might be the TFI module but our car has the ignition control module on the firewall. Is it possible that we have both a TFI (remote, as we cannot find it on the distributor) and an ignition control module? Where would a remote TFI be located with this vehicle, if we have one?
If we don't, is the solution to replace the ignition control module on the firewall or should we look somewhere else?
Old 03-16-2003, 10:05 AM
BigCheech BigCheech is offline
tempo no spark
no TFI on a 86 with a carb:smoker2:
Old 04-03-2003, 04:15 PM
daytonaes93 daytonaes93 is offline
Send a message via Yahoo to daytonaes93
not posative if that car has one but check the cam sensor and the crank sensor
Old 07-10-2003, 08:59 PM
DaGr8Tim DaGr8Tim is offline
The Tempo never had a crank sensor like modern cars. Only the 92-94's had a crank sensor.
Check the idle control motor. Are there any engine codes?
Owner 1988 Ford Tempo GL
Owner 1989 Mercury Topaz LTS
Owner 1991 Mercury Topaz GS
Owner 1994 Plymouth Voyager
www.tempotopaz.com
Old 11-21-2003, 01:12 PM
slickest slickest is offline
Re: 1986 ford tempo (no spark)-sudden loss of power
My 86 Tempo has the same setup and the same problem. Did you ever fugure out what it was?
thanks
larry
[email protected]
Old 01-16-2005, 11:56 AM
89ltd 89ltd is offline
pickup coil in distributor...
Old 03-13-2005, 02:32 AM
UnexplodedCow UnexplodedCow is offline
Send a message via Yahoo to UnexplodedCow
Hmmm, carb on an '86? They were never spec'd to have those after their first year, '84. Custom job, or just a mistake? And the above people are right, an '86 doesn't have a crank sensor. It's got mechanical ignition, and a map sensor style engine. Nothing major. I had a dead '86 in my yard for parts.
a CHALLENGE!! ('93 5.7 Intermittent no-spark) cmjj42 Roadmaster 3 05-06-2009 11:55 AM
1986 Ford Tempo LX Blowing Fuse/s HELP!!! Mayflower General Discussion 3 03-31-2005 11:02 PM
1986 ford tempo will not turn over with booster only clicks bigguy General Discussion 1 07-10-2003 09:50 PM
