Old 01-19-2003, 10:41 AM
Touge180 Touge180 is offline
Side Moldings
do i have to take my doors off to take the side modlings off please tell me i don't cause it's to cold.
Old 01-19-2003, 12:09 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
doors off, no. interior panels off, yes....if you want to try and salvage the clips.
i just priced this at honda on thursday....can you believe it's $70.00 a side for a set of new moldings and clips?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-19-2003, 12:29 PM
erbinone's Avatar
erbinone erbinone is offline
Yeah, I couldn't believe it either. I did my SiR con. and I got the 91 moldings and for them to match the bumpers and fenders, I needed 88-89 moldings. I about fainted when they told me the price @ the dealer. I tried parts houses but, they don't want to separate them from the door. Good Luck. More detailed instructions on taking off the moldings and clips please???
Old 01-19-2003, 06:44 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
You can remove the side moldings without removing the doors, or the interior panels, but only if you don't care if you mess them up...
At the rear edge of each door, just inside, there is one nut that secures the rear edge of the molding... if you remove this nut, then you can just pull the molding off starting with the rear end, but it will crease the moldings, and you won't be able to re-use them. It will probably also bust alot of the clips...
When I took mine off, most of the clips stayed on the car, and the molding just popped off of the clips... Most of the clips can be removed without breaking them by grabbing them with pliers and twisting them 90º and then pulling them out.
Old 01-19-2003, 10:35 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Exactly what i did!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
