Old 01-19-2003, 09:50 AM
Integra06's Avatar
Integra06 Integra06 is offline
Making bodykits
When making a bodykit, how do you make the flat parts for vents on the sides? Everytime that I try, they come out deformed and don't look right. Also, how do most people get the filed parts looking so smooth? Thanks for the help.
Come see AF's new Fabrication board.Click here!
Old 01-19-2003, 01:33 PM
hirofkd's Avatar
hirofkd hirofkd is offline
It depends on what kind of material you are using. Certainly, you can get a flat vent with putty, but that's very hard, and I don't see many people do that. So, just use pieces of styrene sheet.
To achieve a smooth surface, follow the basic rule of body prep. Hand brush the primer, and sand, starting from 600 grit to 1200, then spray the primer, and finish it with 1500 or 2000 grit. Finally, polish the primer with compound, and you should be able to achieve a very smooth surface like bare plastic.
Hiroaki Fukuda
Old 01-19-2003, 01:37 PM
clatescivicr clatescivicr is offline
Hand brush primer??
I've never heard of that, unless that is a modeling thing.
Clate - I'm back
Old 01-19-2003, 02:11 PM
hirofkd's Avatar
I meant
"...brush paint the primer..."
Sorry.
Hiroaki Fukuda
Old 01-19-2003, 02:28 PM
Why not just spray primer?
I meant
Sorry.
Clate - I'm back
Old 01-19-2003, 02:34 PM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
i never used brush primer before, but if you spray primer u usually get it over parts u dont need to check on, if u brush u can just put it exactly where u need it, am i right? and by the way where can i find some brush primer?
Rui
(modeling) = Click Here
Old 01-19-2003, 02:36 PM
That is what I was thinking too since that is what I do when I repaint rust spots on real cars.
I would think any paint shop should have it? I even think Testor's has primer in a bottle.
Clate - I'm back
Old 01-19-2003, 02:44 PM
daggerlee's Avatar
Brushing primer helps fill in more scratches because the coat is a lot thicker. This way, you don't have to flood the entire car in primer in order to get those scratches from sanding.
Dan
