Old 01-19-2003, 03:23 AM
mengy mengy is offline
why is changing the timing belt so hard?
or am I just doing it wrong?
Old 01-19-2003, 09:03 AM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
To me it's not that hard at all but it may be different for you. Just support the oil pan and drop the drivers side motor mount and pull the crank pulley off after getting the crank aligned to the mark. Pull the covers off the timing belt, slide old belt off....change water pump (optional but i always do) after you have drained the radiator-of course. Make sure cam sprocket is aligned with the side to side marks put new belt on and do everything to reassemble. I can do a belt in about a hour and a half.
Old 01-19-2003, 09:09 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
its easier if you swapped ur engine, just to do it before you put the new motor in, but he has a great explanation for installed engines.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-19-2003, 10:03 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Get chiltons or haynes manual to help you through it, and do replace your water pump while your in there......
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 01-19-2003, 11:50 AM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
I AGREE WITH GUNNMAN,
YOU COULD GO ONE STEP FURTHER AND GET THE FACTORY HONDA SHOP MANUAL FROM HELM.
YOU CAN ORDER IT AT ANY HONDA DEALER, IT WILL RUN YOU ANY WHERE FROM $50-$100.
Old 01-19-2003, 12:59 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
that was the whole timing section. if you would like to download the whole helm's stop by: http://www.quickhonda.net/index2.htm
in the links on the left click "garage" and then "service manual"
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-19-2003, 01:05 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Eh Ami do you have one for DOHC ones? These info may come in use for me in the future. I get the idea on how to do it but just incase i fuck up
Old 01-19-2003, 01:16 PM
amy@af's Avatar
naw, i wish. 91ZC posted that link up one day and i saved it. it was only for d series
