Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-18-2003, 06:25 PM
daveauth21's Avatar
daveauth21 daveauth21 is offline
engine upgrade?
is there any way you can get extra hp in the engine it self? (like port and polish,modified piston,larger fuel injectors larger throddle body etc)
Old 01-18-2003, 06:56 PM
Pick Pick is offline
You can stroke your motor out. Some guy did it to a 4th-gen on the dot org.
Old 01-18-2003, 11:42 PM
bk2kmax's Avatar
bk2kmax bk2kmax is offline
Re: engine upgrade?
Port & polish does nothing for hp gains, it only clear up flash & caster left over in the engine when it was built at the manufacturer. When the job is done it allows water (coolant) to circulate better with less obstructions to help cool the engine, it also helps prolong the life of your engine as well.
But you can also do just as Pick said and have an all motor beast.
By the way, it should read bk2k3Max, not bk2kmax.
