Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 12-22-2007, 09:16 AM
ilxciteu ilxciteu is offline
Unhappy Heated seats shutting off
I have a 2003 Tahoe and when I turn on the heated seats they stay on for a minute then shut right back off. Any thoughts on what could be causing this and where I should check first????
Old 12-22-2007, 01:38 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Heated seats shutting off
If equiped with one, check the circuit breaker and the amp draw from the seats. If only one is turned on will it stay on?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-07-2008, 01:47 PM
Acutally if the drivers side is on and you turn on the passenger side they both shut off and vice versa.
Old 01-24-2008, 10:44 AM
bsweasel bsweasel is offline
I have an 04 with very similar results....although sometimes it actually works and stays on long enough to get warm. Also when I press the button...I here a small faint click from under the dash??? is this normal? Relay under there somewhere? Any info on troubleshooting this problem would be appreciated.
Old 01-24-2008, 11:08 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
One relay click when they are turned on is normal.
A factory repair manual or a All data online repair info sub. is you best repair and trouble shooting info.
http://www.alldata.com/products/diy/index.html
The free AZ web site has some All data repair info.
But do not know if they get into heated seats.
MT
MT
