Old 01-18-2003, 02:58 AM
j2kfreak j2kfreak is offline
Send a message via ICQ to j2kfreak Send a message via AIM to j2kfreak
Supercharger
Need to find a good place to get a supercharger for my 97 2.4L cavalier. And maybe even a turbo and is it a good idea to get both or not if not then wich one would be better?
thanks!
Old 01-22-2003, 07:24 AM
Pikachoo's Avatar
Pikachoo Pikachoo is offline
Send a message via AIM to Pikachoo
I personally like superchargers, because you get a flatter power curve. With a turbo, your engine won't put out max power until you max out your RPM's, beause it rely's on the exhaust to supply the turbo with power to provide boost, meaning that the turbo isn't spinning it's fastest until your higher RPM's, i.e. when the motor is producing the most exhaust. This yields a slower takeoff. A supercharger on the other hand, operates off of the belt drive, so it provides boost at almost any RPM.
However, note that a turbo yields the most max power, it's just very high in the RPM range. Also, you can adjust the boost of a turbocharger from inside the car by getting a boost controller. That way if you dont' wanna thrash your engine for daily driving you can turn the boost way down, but when you race, crank it up!! A supercharger requires you to chage pully's under the hood to change your boost. It only takes about 5 minutes, but it's not as convenient as a turbo boost controller.
You can have both. Then the supercharger engages at take off, until you get to a certain RPM, then it shuts off and the turbo kicks in. This gives you the best of both worlds... and if you have some huge stash of cash laying around then go for it.
There are about a thousand turbo kits out there for the cavy's... I would just go to google.com and run a search for "2.2 cavalier turbocharger"
Here's the first one I saw... http://www.dragevolution2200.com/Evo...Turbokits.html
And I believe that GM Performance Parts is offering a new 2.4L Twin Cam supercharger kit.
Hope that helps a little. :sun:
Cruising a Z24 right now, But I've got plans....
http://www.lingenfelter.com/lpe%20-%208%20sec%20Vette.mov
Old 02-06-2003, 05:51 PM
mugenrsx mugenrsx is offline
tuning
It would be very hard to tune a car with two forms of forced induction.
whos my bitch
