Old 01-17-2003, 06:58 PM
DOHCrx DOHCrx is offline
Send a message via AIM to DOHCrx
Unhappy Zc In Heat!!
OKay OKay... I need some help here people.. i have a ZC motor, just freshly swapped about a month ago.
Yesterday morning the heater in my car was only getting warm.. NOT HOT. That afternoon i was driving home and the car started to over heat so i pulled over and turned it off, then started it again and it was at normal temp until about 4th gear and it overheated again. it did this all the way home so i ended up rollin home at 20mph.
I called the mechanics and talked to all my friends.. they said it was the thermostat.. so i replaced it this morning.... No Luck... it still overheats and now the engine light comes on..
Also i have a new water pump.. and a new radiator.. i dont know what else it could possibly be.. and now the air in the car doesnt heat up at all, its just blowing cold air.. if that means anything.
this is how i feel!
Old 01-17-2003, 07:02 PM
toontowncivic's Avatar
toontowncivic toontowncivic is offline
I really wish I could help but I was gonna say your thermostat...but now I really wanna know wha it is...hmmm. Good luck!
STOLEN!
Old 01-17-2003, 07:12 PM
GTA's Avatar
GTA GTA is offline
Whee..
did you replace the water pump and radiator yourself? if so did you bleed the cooling system...there might be air in the cooling system casue the coolant to dissapear which in turn causes over heating.
To bleed the cooling system, follow the upper radiator hose to where it connects to the engine. You see a lil thing like a bolt with a hole in it. loosen it and fill the cooling system until it flows out of that with no bubbles. Then tighten it and fill everything to spec.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 01-17-2003, 07:24 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
To bleed it you can also just take off the radiator cap when the engine is cold and turn on the car and let it bleed itself.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 01-17-2003, 08:40 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Could be something wrong with your heater core?
Old 01-17-2003, 09:14 PM
88CRX's Avatar
88CRX 88CRX is offline
My DX did that then the head gasket blew and the head cracked.
It could just be your thermostate. Does the upper rad hose get hot after the engine is warmed up? If it gets hot then the thermostate is ok. If it wont get hot then you need a new thermostate, only a $10 part.
If your thermostate is ok then it could be you head gasket. If thats the case dont drive your car or you will screw up the head like I did
zc powa
short ram intake
dc sports header
2.25 Magnaflow exhaust
h/r race springs
Old 01-17-2003, 09:40 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Make sure its bleed thats what it sounds like to me.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 01-17-2003, 09:44 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
it could also be your coolant temp sensor.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-17-2003, 11:59 PM
Thumbs up ITS BEEN FIXED!
I flushed the coolant system and noticed a loose ground on the injectors and on the thermostat housing.. now it runs perfect!
time to go burn some rubber!
Old 01-18-2003, 12:18 AM
seth 90DX/ZC seth 90DX/ZC is offline
Banned
Hehehe... Thats great! How do you like that motor VS the stock one? I have a D16A6 in my car now (swaped it in about 4 months ago) and a JDM DOHC ZC in my back yard But Ima rebuild the whole bitch before it hits my engine bay! Im lookin at spending $3000-4000 on the motor before it hits my car! ALL MOTOR... I have a seriouse itch to show these "B" ass mother fuckers whats up with the OLD SCHOOL!
Old 01-18-2003, 02:11 AM
Thumbs up ZC Power
Hell yeah dude, ZC is killer! I should've done internals on mine but it was really a spur of the moment swap.
Now i can keep up with B16's with no problem!
Old 01-18-2003, 03:23 AM
Banned
Realy? You meen 2000 SI's right? I meen a B16A in a 88-91 would smoke you right?
