Old 01-17-2003, 08:18 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Question Will High octane make much of a difference??
Every time i go to fill up i see the high octane fuel and wondering if it will make much difference, I have been told by some people that it burns out the valves, but do you think it would be OK to run my D16A9 on it and would I get better performance with it
any help welcome
Cheerz
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 01-17-2003, 08:21 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
you wouldnt see much of a performance in a low modded car, but it will give you something, plus it has higher anit-knock additives for when you run boost or high rpm applications.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-17-2003, 11:45 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
yea, it will make a little bit of difference. Don't know really if its better for the engine or not, but I run 91-93 Octane whenever I can.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 01-17-2003, 11:52 AM
darolh darolh is offline
If your engine is not knocking it will make no difference and do no harm....except to your wallet. I actually backed off the spark in my car a bit cause I get a tiny little bit of knocking in warm weather. If I climb over the pass in warm weather I put medium grade in so it doesn't ping.
1st: Check your timing. If it's correct and you're pinging either go to higher octane gas or back off the timing a bit. It's your choice. You'll lose a little poop by backing off the timing.
Old 01-17-2003, 11:58 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yeh doesn't make any bid difference. I put 100 octane on my car and still the same shit. Its harder to get my car started at first cause of the high octane but then the second crank it starts up fine. Its good for your engine either way if u use 91-94 octane.
Old 01-17-2003, 01:22 PM
Redrum240sx Redrum240sx is offline
Send a message via AIM to Redrum240sx
high octane and octane booster can help your cars hp if your car is heavily modified if you run an octane that is to high for your car you could actually lose hp
93 Del Sol S
Eibach Sportlines
Tokico HP's
EBAY Strut/Stabilizer Bars
EBAY Short Shifter
Baer Track Kit
Old 01-17-2003, 02:30 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Originally posted by JDMB16 @ illusiverides.com
ok, don't use 93 octane man, Civics don't need it. Higher octane fuel without major mods like higher compression pistons, turbo, n2o, SC etc. will make your car run rich hurting performance. Stick with 87. And also, you won't actually get more power, with major mods as listed above, you can get detonation hence the reason why we would retard the ignition timing and use a higher octane fuel.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 01-17-2003, 02:40 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
I only have a DX with a few mods but when I switched from 89 to 91 I noticed a little more pick-up when passing & my mpg went from 33 to 35. Every couple months I put a gallon of MTBE & cleaner in with a full tank & it just gives me a little refresher & a few more mpg's.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 01-17-2003, 02:58 PM
red4thgencivic's Avatar
red4thgencivic red4thgencivic is offline
Send a message via AIM to red4thgencivic
Higher octane fuel burns slower than regular fuel, that's the only difference, the octane level is just a rating of how much the fuel has been processed. Kinda like a rating of how pure it is.
The only reason you would need high octane fuel is if you have very high compression something like 11.5:1 or higher. THis high compression results from mods such as turbo, n2o, and things of that sort, if you're having problems with valves knocking or anything it's probably just your timing.
Why can't money come easier?
ok so i had two civic hatchbacks, i totaled one because i wasn't paying attention, the other one i got ran into a creek by an old lady asleep at the wheel, then i got a CRX was being retarded hit a deer at 90 and flipped, so now i drive a 1992 celica GT and i love it, done with being stupid, this one will not be wrecked.
Old 01-17-2003, 03:05 PM
mellowboy's Avatar
It's not necessarily slower as much as it is cooler. Supposedly the higher octane you use, the cooler the burn is. That's why when you start doing performance upgrades, people recommend going at least with a 91/92 octane fuel to aid in the prevention of detonation(knocking or pinging).
Old 01-17-2003, 03:35 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
Thats not right. The octane rating tells you how much the fuel can be compressed before it spontaneously cumbusts. Pinging is caused when the fuel ignites before the spark fires, Its called pre-ignition. The reason they recomend higher octane when you start to modify is because usually one of the thing people do when modding is raise the compression or ad some type of forced induction which causes higher compression.
Therefore...if your car doesnt need it then you will most likely see no gain in performance. Those of you who do see a performance between low octane and high is because most gas companies water down the low octane to make more money.
Old 01-17-2003, 03:49 PM
kris's Avatar
kris kris is offline
Off playing with fire.
:o I will need it when my motor is finished.
Old 01-17-2003, 03:50 PM
mellowboy's Avatar
How high u gonna get? The compression!
Old 01-17-2003, 03:52 PM
kris's Avatar
Guesstimate is around 12.5:1
Old 01-17-2003, 03:54 PM
mellowboy's Avatar
Yeh i'm gonna be doin the same except on a b-series. I sold my d16a6 to my friend and he got arias 11:5:1 compression with crower rods. Hes gonna do the head soon. He got an upgraded clutch act. that shit pulls hard man. Just imagine fully built...
High Beams not much different from main beams scubamartin Galant 2 04-14-2019 05:52 AM
Does High Octane Fuel really make difference??? sydgrant1 Tundra 5 09-22-2005 09:59 PM
will new wheel bearings make any differance? lucki17 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 06-29-2004 10:07 PM
Will this head make a difference? JimCRX '88 - '91 Civic | CRX | Wagon | Shuttlee 0 03-02-2004 12:59 PM
Will Headers make a difference? GURLSVTEC Exterior | bodykits | Lighting 5 01-12-2002 07:54 PM
