Old 01-16-2003, 03:52 PM
tynebeach tynebeach is offline
Send a message via AIM to tynebeach
helping out an old motor....
a friend on mine just bought a civic and it has fairly high miles on it, I believe around 130K. There doesn't seem to be anything mechanically wrong with it, but I still think he should get SOME things done to it so it lasts longer. I was thinking maybe putting in new spark plug wires and topping off all the fluids and I don't really know what else. If someone could help me make a list of things that aren't that expensive but are a good idea to do that would be great! thanks.
91 Eagle Talon: Exhaust, ported turbo/mani/o2 housing, 15 psi, short route FMIC, etc..
96 Toyota Corolla: DD
Old 01-16-2003, 06:30 PM
b16a3sol b16a3sol is offline
normal tune-up things are always a good place to start. replace plugs, wires, cap, rotor, fuel filter, air filter, oil, oil filter and top off all fluids. you can change out the fluid for whatever is powered in that car like brakes and steering. change out the coolant. there are probably some more things to do, but that will keep you busy for a little while.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 01-17-2003, 01:57 AM
Rgacke's Avatar
Rgacke Rgacke is offline
timing belt/water pump!
"shut the door Joshua, and let death pass by..."
Old 01-17-2003, 06:41 AM
how much do those things run?
Old 01-17-2003, 08:13 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
these are estimates, but should all be pretty acurate, but im basing them on NY prices.
cap - 8
rotor - 3
wires - 30
Oil - 4qts - 6-10 depending if you use reg. or synthetic.
plugs - 5 - 25 depeding on regular or multi platinum
timing belt - 45
water pump - 65-85
oil filter - 4
fluid top off - depends how much you need.
fuel filter - 10
air filter - 15 - 45
again these are just estimates but they should give you a good idea.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-18-2003, 12:00 PM
sweet thanks alot, so you think if I put about 200 to 250 in it i can probably keep it in good condition? I'll keep this list
Old 01-18-2003, 05:39 PM
crxlvr's Avatar
yeah it will prolly run alot better too.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Headlights dont work - Please help an old woman out barry_mann Century 1 11-12-2009 02:35 PM
help headlight popup motor is out wederquist Probe 2 04-27-2006 05:56 PM
Help, I need to change out a motor dougsoval Aurora 0 07-26-2004 07:51 PM
Old motor is out.. kris '88 - '91 Civic | CRX | Wagon | Shuttlee 8 05-04-2003 04:38 AM
old motor out...new one in soon canned4thgen '88 - '91 Civic | CRX | Wagon | Shuttlee 4 04-10-2003 12:26 AM
