Old 01-16-2003, 10:04 AM
aznbum aznbum is offline
removing headlight 1997 accord
my friend has a honda accord and i am going to change it for him, I was just wondering how to remove the headlights and the clear corners off the car.
Old 01-16-2003, 10:44 AM
Rollinon18s Rollinon18s is offline
Send a message via AIM to Rollinon18s Send a message via Yahoo to Rollinon18s
Are you just replacing the bulbs on the headlight?
The corners come off it looks like by unscrewing 2 bolts.
Nicole =)
Old 01-17-2003, 09:32 AM
DemonicAccord's Avatar
DemonicAccord DemonicAccord is offline
Send a message via AIM to DemonicAccord
on a 97 its just one screw for the corners and four for the headlight assy. The headlight, when looking at the front of the car, has two screws on top, one toward the center of the car to the left or right of the grille depending on which headlight you're doing and one down low behind the bumper. It is possible to get the headlights out w/o removing the bumper, but the bumper comes off so easy, i just took it off when I did mine.
If you don't remove the bumper then at least remove the screws at the wheel well and bend the bumper down and forward, that will allow you to either reach in and unscrew the bolt from the wheel well side or from underneath.
Old 02-02-2003, 09:16 PM
Squintz0321 Squintz0321 is offline
Send a message via AIM to Squintz0321
Wuz up yung...... I have a "97" Accord too !!! I changed my corners about 3 months ago, all you gotta do is unscrew the scews that are under the hood and then pull and they pop right out. For a 97 the bulb size is 9006 for the low beams. Hit up my page in a few days and i'll have some pics of my car on there aight. Saty up yung !!!!
~~Squintz~~
1996 Honda Accord LX sedan/ Hyperwhite corner lenses-bulbs/ Huperwhite bumperlenses-bulbs/ Generation II Euro Tails/ 35% tint.......
Old 03-23-2004, 09:07 AM
MercOne MercOne is offline
Re: removing headlight 1997 accord
I wanted to replace my headlight bulbs both low and high beams. I wanted to know if there was a walkthrough, or if there is a picture guide as in the web page mentioned above. Thanks.
Old 03-23-2004, 09:38 AM
just open your hood and look at the back of the headlight assy, you will see a lock ring around where the wire enters the housing, simply turn that as the arrows on the lock ring say ( i forget which way for off) and the bulb/base/harness will pop right out
Disabling Automatic Headlights - 1997 Regal GS TrinaR1231 Regal 1 12-04-2010 05:37 PM
How to remove headlight LENS on 1999 Grand Marquis LieutenantCracker Grand Marquis 0 01-29-2010 10:53 PM
removing a 1997 ford escort headlight gizmutt Escort 2 08-11-2006 06:46 PM
How To Remove A 1997 Dodge Avenger Headlight??? green_avenger Avenger 8 11-22-2005 12:51 PM
removal of front bumper 1997 accord asdfjkl666 Accord/TSX/Accord Hybrid 7 08-27-2004 08:34 AM
