Old 01-16-2003, 01:12 AM
SyNFuL HaTcH's Avatar
SyNFuL HaTcH SyNFuL HaTcH is offline
Send a message via AIM to SyNFuL HaTcH
Question Interior Question
i was wondering if the jdm door panels from a 88-89 civic/crx would fit on a 90-91 civic/crx. also wat are the diff. between them cause i wanna get some from the pic below. i know it doesnt have the seat beal on the door like mine does but i was thinking on a custom job of doin it but i would like to know if they would fit or not.
Old 01-16-2003, 01:14 AM
o yea if they do fit would doin the seat belt thing be hard ?? anybody knows ????
Old 01-16-2003, 05:08 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I think that the CRX ones would fit the CRX, and the hatch ones would fit a hatch, but I don't think that the CRX ones would fit a hatch and vice versa... those don't look like sedan ones, but I'm positive that the sedan ones would not fit either...
Personally, what I would do (and what I'm ultimately planning on) is to get door panels like that, and remove my seatbelts and put in 3 point harnesses. Even so, you would still have to modify the door panels at the top rear corner to accomodate the rear edge of the window frame (ask travis_118 about that, he's done it).
You may not be able to modify them for use with your door-mounted seatbelts because of the map pockets in them... I think that the seatbelt mechanism would be right behind where the map pocket indents, and it probably won't give you the proper clearance...
Just my thoughts, although I don't have any direct knowledge of that.
Hope that helps.
Old 01-16-2003, 05:10 PM
ci5ic's Avatar
Also, forgot to mention:
On those door panels, it looks like the cutouts for the interior door handles are alot larger than normal, I can only assume that is to accomodate power window and power lock controls, so you may either want to find some of those handles/consoles, or you will have to modify some sort of adapter plate which will be visible around the door handle housing.
Old 01-16-2003, 06:06 PM
well the reason i wanted to know is because i wanted those panels for my jdm power windows im still waiting 2 install. ive had them there for a little over a month but ive been most of the time with school and work & im planing on gettin another job 2 earn more $$$ for a swap. i just wanted to know if they would of fit or not. Thanx 4 the help
Interior design question kinda.loopy88 Non-Performance 0 04-19-2010 02:13 AM
Interior question Don juan Exterior | bodykits | Lighting 2 03-03-2002 08:32 PM
Interior question -=Evol90Accord=- Car Audio 1 02-14-2002 03:35 PM
3 series interior question? nokiauk 3 Series 0 01-31-2002 05:36 PM
interior question. hakushi General Discussion 1 01-11-2002 06:31 PM
