Old 01-14-2003, 07:34 PM
phatmitsu's Avatar
phatmitsu phatmitsu is offline
Send a message via AIM to phatmitsu
Need help on turn signal lights
All right i screwed up big time.. Im working on a civic and i shaved the side molding off, but in the process i shaved off some of the turn signals on the fender.. anyone know how i can scratch build another one on there?? Thanks Later Rick S...
Old 01-14-2003, 07:39 PM
Jay! Jay! is offline
Horizontally Opposed
Re: Need help on turn signal lights
Do you mean the side marker/repeater above/behind the front wheel well?
If so, is the one on the other side still intact?
Hierarchy of Subaru:
(Click to see mine!)
Old 01-14-2003, 08:05 PM
phatmitsu's Avatar
yeh the other side one is fine.. but that is the thing im talking about...
Old 01-14-2003, 08:10 PM
Are they symmetrical? I mean, would it look okay if you flipped it over and put it on the other side?
If so, you can simple-cast a copy of the undamaged one to use on the other side. You may actually want to make two, shave off the other one, and use two of your own.
You'll need white glue (like Elmer's) and model cement... Have those?
Old 01-15-2003, 04:22 AM
Fooesboy's Avatar
Fooesboy Fooesboy is offline
You can also buy realy good indicator lenses, they are quite cheep and look alot better than painting the molded plastic ones.
I will post some more info when I get home tonight.
