Old 01-13-2003, 04:41 PM
benie benie is offline
need help changing the dashborad
how do i get the glass out so i can change the dashboard inside?i only see two screws on top of the frame..where are the other screws?
Old 01-13-2003, 04:45 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
what glass? the glass on the gauge cluster?
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 01-13-2003, 04:53 PM
yes..that glass...and the whole frame..so that i can change the gauge.
Old 01-13-2003, 06:51 PM
hondacivic4drlx's Avatar
hondacivic4drlx hondacivic4drlx is offline
Send a message via AIM to hondacivic4drlx
you want to change what?the dash is held in by like 30 screws but you do not need to pull the glass for that.
Old 01-13-2003, 06:59 PM
markpa's Avatar
markpa markpa is offline
Guy are you changing the gauge cluster or the entire dashboard, gaugle cluster shouldnt take you more then 10 minutes but the entire dashboard is a full day project.
Old 01-13-2003, 07:12 PM
the gauge..thats what i wanna change..the gauge.
Old 01-13-2003, 08:34 PM
CraniumDesigns's Avatar
CraniumDesigns CraniumDesigns is offline
Send a message via AIM to CraniumDesigns
If it's your guage, just unscrew the 2 screws in the top of the black plastic piece that surrounds the gauge, then there are 4 screws holding in the entire assembly in the 4 corners. after you remove those 4 screws, you can just snap off the PLASTIC that covers the gauges. just BE VERY CAREFUL not to break the needles!!! i broke mine and it cost me $30 for a new gas/temp assembly!
Steve Davis
AF Bay Area Crew
WEB DESIGNER!
www.craniumdesigns.com
Old 01-13-2003, 08:56 PM
markpa's Avatar
yor describing how to take off a 96 cluster he has a 95, its a bit different, first unscrew the two top screws, then you have to lever out the hazard lights switch out, and then you disconnect that, now you should see one more screw where the hazard lights use to be unscrew that one, becarfull so that it doesnt drop, then you have to take the enitre plastic thing of with the vents, i suggest you start at one end and work to the other way, this thing is held by i believe four clips, use a bit of force but not too much cause it will snap, after you have the taken off youll see the gauge cluster itself is held by four screw unscrew those and then unplug the harness, and youre done. I dont think i missed anything but if i had can someone please add. Good luck man. Why are you changing it?
Old 01-13-2003, 10:07 PM
damn. i'm glad they made it easier in the 6th gens.
Steve Davis
AF Bay Area Crew
WEB DESIGNER!
