Old 01-12-2003, 07:46 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
si ecu
after reading something ami posted about putting mpfi and si ecu in a dx for a cheaper mod before getting an engine swap, i decided thats what i wanted to do, so i found both but havent ordered the si ecu yet. but i was at the races last night and my friend who is sorta a 4thgen. expert/owner told my boyfriend that si ecu will not work if i hook it up to my dx, that the car wont even start? did i miss something? i know for sure i read the post right, is my friend wrong? help me out guys
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 01-12-2003, 08:01 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
you need to get the injector resisterbox and a believe the dist. too, and switch a wire on the tps i reckon...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 01-12-2003, 08:07 PM
check this site out
Old 01-13-2003, 01:10 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
the pm6 Si ecu will not just plug in and play. that is right. however, you get the 88-91 Si distributor & convert to MPFI and it's good to go.
you will need the resistor box and intake mani for the conversion as jeef mentioned. all the parts for the conversion will run $150-200 and the dizzy around $60.
check out: http://www.4thgenerationcivic.com/ho...conversion.htm i got that info out of Sport Compact.
if there is anything i can help with...please feel free to e-mail me [email protected] :jump:
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-13-2003, 04:55 PM
Rgacke's Avatar
Rgacke Rgacke is offline
SCC did one of the best write ups I've seen so far. Glad you posted the link 'cause thats one of the issues I'm missing.
"shut the door Joshua, and let death pass by..."
Old 01-13-2003, 10:11 PM
thanks, for the info its really cool when u guys are friendly and really willing to help but after i found out how much work it was gonna be i decided im really itching for the swap i gotta get it!!! this credit card company sent me a card with a limit of 5k so i think im gonna call them up and make sure everything will go thru smoothly, and then getting a swap, im so excited im going sohc vtec if anyone cares to know, does anyone have this swap? i decided with this one because its cheaper than b16 and has great potential and i dont need too much debt cuz i might be off to a different college next year!
Say NO to Primer!!
Old 01-13-2003, 10:17 PM
civicracer_1990's Avatar
civicracer_1990 civicracer_1990 is offline
I've done a few of them and they are rather easy........though the first one was a bitch.............If I were you I wouldn't use the pm6 I'd use the pg7....which is the 89 ls integra ecu...........I have EVERYTHING including sohc vtec mini-me motor going up for sale soon..........I'm doing a non obd to obd 1 conversion very soon.........
"Faster and Faster until the thrill of speed overcomes the fear of death" Dr. Hunter S. Thompson
Old 01-13-2003, 11:22 PM
amy@af's Avatar
i have a d16y8 sohc vtec
don't use the teg ecu. get a 92-95 p28 ECU. then you can get a wiring conversion harness....extend 8 wires and it's plug n' play.
let us know how it goes
Old 01-14-2003, 12:24 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Before you do anything, check out this site:
http://hybrid2.honda-perf.org/
They are super reliable, and accurate on everything. I used their diagrams and stuff when I wend from DPFI to MPFI for my ZC swap. These guys have done their research and won't lead you astray. I would have to back Ami up and say that you should not use the Teg ecu with the SOHC Vtec motors.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 01-14-2003, 06:19 PM
actually my friend recommended i do a 96 or a 97 sohc vtec swap over a 5th gen sohc vtec swap. what do u guys think? i appreciate and take into consideration your guys input just as much, i dont post much but i look around a lot and i know most you guys have credibility. does the 5th gen. drop right in w/o new mounts? Ami you have sohc vtec? how do u like it, do u recommend it?
Say NO to Primer!!
Old 01-14-2003, 06:31 PM
amy@af's Avatar
your stock mounts work fine and dandy.
i have the d16y8. it was easy because i have a Si and already had MPFI. i say the 5th gen might be easier because it's fuel injectors run the same impedance (sp?) as the 4th gen. in the d16y8 (96-00 Civic EX) they lowered the impedance again. people have been doing the d16z6 (92-95 Si/EX) swap for many years. i know many sites with swap info. swapping in the d16y8 is fairly new concept. i don't know if i have even seen a site addressing the MPFI part of the converion when swapping the y8 into a DX.
i say check out the z6 because the installation process is known. i'd hate you to get a y8 and get lost in some shady areas.
do i like it? well, i'm all about the d series. i liked my d16a6. when it had troubles it was time for something new. i wasn't out looking to break speed records with that said, i love the y8. since you'll be starting with a d15....you'll probably like it too. i get the feeling you're looking for more but don't expect 12's
