Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 01-12-2003, 12:24 PM
lilcid lilcid is offline
Send a message via AIM to lilcid
Question keyless remote programming - help!
Hi,
Does anyone happen to know how to program the keyless remote for a 92 oldsmobile 88 ?? Any help would be great. Thanks!
Old 05-30-2003, 08:22 PM
Davanna Davanna is offline
Smile maybe this might help
i have been reading some post and maybe the produdure is the same,, hope it helps http://www.automotiveforums.com/vbulletin/t42794.html
Old 05-30-2003, 10:11 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Olds 88 is a different procedure! I can't remember it right now!
Old 08-07-2003, 09:15 PM
RoccoT RoccoT is offline
Send a message via AIM to RoccoT Send a message via Yahoo to RoccoT
Remote programming for 93 Olds Silo
Can anyone give me the procedure to program the remote for a 93 Olds Silhouette?
I picked up a Delphi remote on eBay part number 9364556-4575
Old 08-27-2003, 04:54 PM
delta88 delta88 is offline
this is how to program my olds toronado, its a 1990 but this works for buick and caddilacs. open the trunk and under the third brake light pull down the trunk material. if your car is optioned with the keyless option there will be a small black box with a wire with a green plug at the end of it. ground the wire to the body. the doors will lock and then unlock... press the unlock on the 1st remote ...wait a sec and then do so on the other remote.. if you have only one remote do it twice with the single remote.. remove the wire and give it a try....
Old 02-14-2005, 04:25 PM
ellismiller ellismiller is offline
Re: keyless remote programming - help!
Remote programming instructions needed for 2003 Oldsmobile silhouette with 2 power sliding doors needed.
Old 06-11-2005, 04:52 PM
BadAss318Dakota's Avatar
BadAss318Dakota BadAss318Dakota is offline
Send a message via AIM to BadAss318Dakota Send a message via Yahoo to BadAss318Dakota
Re: Re: keyless remote programming - help!
Take it to Gm dealer they have to program through the body control module using the Tech 2 Scan tool
