Old 01-11-2003, 07:15 PM
tc3house's Avatar
tc3house tc3house is offline
Send a message via AIM to tc3house
Question paint-to-polish time?
after checking the FAQ i couldnt find these answers
how long after i have painted the body should i start polishing it?
another few q... should i hit it with a coat of clear coat before i polish?
when should i use my gundam marker inbetween the body panals, before the alleged clear coat or after?
Old 01-11-2003, 10:04 PM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
Talking Answers
After u spray it leave it for about 48 hours so it can completely dry. Then after 48 hours put some wax on it and wipe it off with a soft towel or old t-shirt, and after start buffing to make it shiny.:flash:
Old 01-11-2003, 11:22 PM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
I think P-man leaves it for about a week... correct me if I am wrong though.
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 01-11-2003, 11:36 PM
This is true, you want the paint to harden before you do this, make sure you use Primer so the paint has something to grab on to.
Depending on the color, if it's metallic then you should use clear coat, also depends on the color, what color are we talking about here?
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 01-11-2003, 11:41 PM
bvia's Avatar
bvia bvia is offline
Talking
A general rule is to wait until the paint stops smelling like paint (it should then be though gassing out). So if it stinks, I wait until it doesnt anymore ;-)>
hth,
Bill
:bandit:
Old 01-12-2003, 03:14 AM
jon364 jon364 is offline
Send a message via AIM to jon364
I use duplicolor paint, and I only wait maximum of two days for hte paint to fully dry. Sometimes even less
Old 01-12-2003, 03:24 AM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
I took a shoebox and poked about 50 holes in the top with a knife, turned it upside down and stuck my model under it for a week. That way the paint can cure without getting any dust in it. I wouldn't even touch the paint for at least a week. I think it was about 8-9 days after painting it that I waxed it.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 01-12-2003, 06:36 AM
flyonthewall's Avatar
Car Mod guy
I wait for 1 week minimum.
Old 01-12-2003, 08:14 AM
daggerlee's Avatar
The longer you wait, the safer you'll be.
Duplicolor lacquers are the fastest drying/curing, followed by Tamiya spray paints (at a minimum of 4 days). Keep in mind dry/cure rates are affected by ambient temperature (room temperature) and humidity. So if you put it in a cold room it will take more time to cure/dry. I'd say, to be on the safe side wait at least a week.
Dan
Old 01-12-2003, 09:40 AM
tc3house's Avatar
thanks guys!
the color i'm using is tamiya orange, and dont worry i put primer on before hand
Old 01-12-2003, 11:27 AM
=p
I wait for about 48-50 hours then i wax it with "Meguirers Wax":flash:
Old 01-13-2003, 08:13 PM
primera man's Avatar
"P-Man"
Re: paint-to-polish time?
Wait at least 7-10 days
I'm not a fan of clear coats. IMO if you get the paint sprayed on right and you give it a good rub and polish there is no need for clears.
I'd leave the panel lines to last if you are clear coating as they will turn out with a gloss look which they shouldnt be. Yopu need them to look like a matt finish..
View All My Models Here.
