Old 01-11-2003, 03:19 PM
socki socki is offline
Send a message via AIM to socki
Question What is torque?
I really don't know anything about cars but could someone give a quick explination about what torque is? Thanks,
Adam S.
Old 01-11-2003, 04:20 PM
Deakins's Avatar
Deakins Deakins is offline
http://www.howstuffworks.com/fpte.htm
The ringing of the division bell, have stopped...
AF User Guidelines
Old 01-11-2003, 04:56 PM
911GT2 911GT2 is offline
Torque is the force put upon the crankshaft, power is this work done over time.
Some people deserve to have their vocal chords ripped out. Oh yeah, and American beer is like having sex in a canoe...it's fucking close to water.
Proud member of www.automobileforum.com
Mod -www.autoworldforums.com
Old 01-11-2003, 07:53 PM
Steel's Avatar
Steel Steel is offline
T= F*d
Old 01-12-2003, 12:15 AM
FYRHWK1 FYRHWK1 is offline
Send a message via AIM to FYRHWK1
yeah, force * distance, HP is work (TQ) over time (RPM)
more specifically, Torque is the cylinder pressure of the expanding gas times the leverage of the crankshaft journal (reason why you usually see long stroked motors making alot of torque, more leverage) with the rod angle thrown in there as well, but i'm not quite sure how you'd calculate that up.
Old 01-12-2003, 01:51 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Here is most simple explanation I could think of. Horsepower is how fast you can go in a given gear, torque determines how fast you can get to that speed.
Old 05-08-2003, 11:15 AM
bullseye's Avatar
bullseye bullseye is offline
Send a message via AIM to bullseye Send a message via Yahoo to bullseye
i dont no what i would do with out theis site!:cry:
"It is only after you have lost every thing that you are free to do any thing.." -Fight Club
I am hoping to git a datsun 280z or a nissan 300zx woot for me!
Old 05-08-2003, 02:44 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
even simpler think of a tube put one end into a vise and try to turn it along its axis. you just aplied torque to that pipe.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 05-08-2003, 03:48 PM
LB Dinh LB Dinh is offline
This is the bible to automotive basics!!
On topic: Torque is the turning force.
Here's an analogy...say there are two bodybuilders and one 200lbs barbell. Bodybuilder A lifts the barbell once and bodybuilder B lifts it 10 times. It's quite obvious that bodybuilder B is doing more work but both are using the same force to lift the weight.
In this case, force:torque as work:horsepower.
Old 05-09-2003, 11:59 AM
SaabJohan SaabJohan is offline
This is actually wrong.
Mean power output accelerates the car on a given gear.
Power output also determinate top speed.
Torque ia actually worthless in an engine without engine speed, torque multiplied with the angular speed of rotation gives what we want: power.
Old 08-08-2003, 01:37 AM
digger digger is offline
torque at the wheels is what directly gives acceleration ( but since power and torque are related you could also use power and angular velocity of the wheel to give wheel torque). It is also the friction or traction force at the wheels that pushes the car along, this force can be found from the torque at the wheels. Also the wheel radius and car mass are important factors.
Old 08-12-2003, 02:46 PM
454Casull 454Casull is offline
Torque != cylinder pressure != force...
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 08-12-2003, 11:02 PM
try english bucky, that makes no sense.
