Old 01-11-2003, 01:32 AM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
dizzy replacement
i was looking at my chiltons bacause i cannot find my helms when i need it (damn garden gnomes) and it is very unclear on how to replace it
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 01-11-2003, 01:44 AM
BullShifter's Avatar
Its very simple
1. Disconnect the wiring connectors
2. Disconnect spark plug wires
3. Remove 3 hold down bolts - 10mm i think
4. Always replace the o-ring if removing or replacing distrib.
5. Slide distrib in - it can onlt be seated properly 1 way
6. Reverse the process but do not over tighten distrib. bolts
7. Set timing & then tighten hold down bolts to 16 lb ft which isnt much
8. There is way to remove distrib with out having to set the timing - scribe a mark across the distrib & the head. This does not apply to replacment
Old 01-11-2003, 01:52 AM
how do i set the timing>?
Old 01-11-2003, 12:18 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
you really should have a timing light to do it right. you mount the dizzy. before you tighten it down all the way you move it forward or backwards (to advance or retard timing) to adjust timing then tighten it back down.
why haven't you DL the helm's yet? then you'll never loose it. it's for the CRX but still works for stuff like the dizzy. http://www.quickhonda.net/index2.htm. in the links on the left click "garage" then "service manual". you can DL the whole thing at once or in 2 parts. go do it. go do it NOW! okay, why are you still sitting here? click the link already!
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-11-2003, 12:27 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Other manuals also.
http://www.automotiveforums.com/kris...91_usa.pdf.pdf
http://www.automotiveforums.com/kris...hop_Manual.pdf
