Old 01-10-2003, 02:53 PM
cp___32 cp___32 is offline
Drive Axle
I need to change the drive axle on my 89 Civic Si.....I saw a show a while ago where they did this, and they only had to umbolt the brake rotor, and swing it out of the way to pull the axle. Is there anything else I need to do o pull it. If it's really involved I'll take it to a mechanic
THANKS ALL!!!:flash:
Old 01-10-2003, 03:19 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Yeah dude..you need to pull apart the ball joint...that should allow enough movement that you can push the axle in and out of the hub. Be careful when putting a new axle in the tranny that you don't nick the oil seal for the tranny fluid..I wasn't careful and I have little black spots under the wifey's Corolla
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 01-10-2003, 03:24 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
make sure you get the right axle too, dx's and si's have diff amount of splines on them
2002 Acura TL Type S
1991 Honda Crx Si
