Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-10-2003, 12:09 AM
boostedciviSiR boostedciviSiR is offline
Send a message via AIM to boostedciviSiR
Question '97 240 sx s15 silvia swap
i need help. just as i have seen people ask about b16 swaps in civics, you too have probably seen questions about s series swapn in 240 sx's. we have acquired an s 15 clip, wrecked badly in the drivers side but the engine and trans were untouched. ecu nad harness are in good shape. cluster is shot. i need a resource with a break down on the swap info. as i have said i know the honda's like the back of my hand but i am new to the nissans. the clip is pretty much complete with out the fenders and the hood but thats ok. thankyou. and take care...[email protected]
Old 01-10-2003, 03:24 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
Well the S15 sr20 is the hardest to swap into the 240 out of all the SR's. If it's going into an S14 then the tranny mounts will need to be modified a little bit to get it to bolt up to the chassis. Your going to need the S15 differential for this swap because the speed sensor for the s15 is in the differential. If your swapping into the S13 then you are going to run into the same problems as the S14 plus the driveshaft on the S13 has a different mounting location so that will need to be modified.
