Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-09-2003, 10:42 PM
purespeed187 purespeed187 is offline
turbo in 95 GSR
hey i want to put a greddy turbo kit in my car is it safe to do on a stock gsr? Also when does the kit for the 95 come out ???/ I heard about a conversion for the turbo as well but if the turbo is commin out soon ill wait.
Old 01-09-2003, 11:49 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
u can run it at low psi, an not worry, but if u want any type of boost, then upgrade ur pistons/rods etc...simply because ur running at a 10:1 compression already, lower compression pistons will help keep ur motor from going ::BOOM:: when u thinkin bout gettin it? that'd be a nice lil ride...u have anything else on ur car?
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 01-10-2003, 11:04 AM
my car is stock so i will run low psi but then i wil get stage 2 act clutch and skunk2 or apexi exhaust then lower compression pistons and boost controller after that intercooler and blow off valve then a jgedelbrock intake manifod
Old 01-10-2003, 11:06 AM
im thinkin about getting it in about 3-4 months i just want to make sure i can run it on my stock gsr i have about 1000 right now so if i need anything first i will get that.
Old 01-22-2003, 03:09 PM
pontiactrac pontiactrac is offline
turbos are a waste, they tear up your engine
Old 01-22-2003, 06:50 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Only if you don't know what you are doing or if you are wanting to run some unrealistic boost levels. Turbos are just like alot of mods you just have to know how to set it up correctly. If you don't then BOOM!
Don't hate on Turbos man!
Old 01-22-2003, 06:56 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
Amen.... don't go greddy, if you're gonna go turbo go with a drag or revhard kit... personally i recommend the drag, love it to death.:flash:
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
Old 01-22-2003, 10:46 PM
NSX's Avatar
NSX NSX is offline
Send a message via ICQ to NSX Send a message via AIM to NSX Send a message via MSN to NSX Send a message via Yahoo to NSX
Do you mean higher compression?
Turbos can be fun!
Look at what it did to the Skyline GT-R34; Lancia Integrale and all the rest of the Rally cars!
Not to mention Indy cars too!
Old 01-22-2003, 11:39 PM
no, he's going to want lower compression pistons if he's going to do forced air. if u have high compression, u have to run at lower psi, meaning less gains. plus, w/ lower compression pistons, ur motor is a lot less likely to go BOOOOOOOOOM
2003 Infiniti G35
Old 01-23-2003, 02:44 PM
NSX's Avatar
NSX NSX is offline
Oh, well, I have no experience from this; but I'm just following the name, so I thought High-Compression Pistons allow for higher rates of compression[?]
Old 01-23-2003, 03:47 PM
ooo...s'all good, heh, jus wanted to make sure the rite answer was given to him.
2003 Infiniti G35
Old 02-02-2003, 03:12 PM
socki socki is offline
Send a message via AIM to socki
BOOM?
do yall mean that if you put a turbo in a stock GSR, IT could Blow up?
Old 02-02-2003, 10:25 PM
casperGSR's Avatar
you can blow up any motor that you strap a turbo onto, it just all depends on how well built (or not well built) the motor is for turbo application and how much boost your cranking through it's veins.
Old 02-02-2003, 10:28 PM
casperGSR's Avatar
Re: BOOM?
stock gsr... run around 6 lbs and you should be fine for a while, also depends on how hard you drive the car. I've been running in between 6 and 7 lbs on my gsr... put the turbo on when i had 30,000 miles and now have 56,000... car still runs fine but I'm rebuilding the internals this spring so it can withstand higher levels of boost.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
