Old 01-09-2003, 01:19 PM
erbinone's Avatar
erbinone erbinone is offline
Replacing Blown Head Gasket
When replacing a blown head gasket. Do I need to have the heads re surfaced or can I just replace the gasket and clean out the oil and I'm done?? What's the best method??
Old 01-09-2003, 01:21 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I think if the head looks warped then have it machined. But if you think it's ok and looks straight then don't bother. By the way I think you can use Z6 or Y8 head gaskets or something and they are metal which is better than the crappy cardboard our cars came with.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 01-09-2003, 01:22 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
it depends on the damage on the head. Usually you wont have to get any machine work done. Just make sure that all of the old gasket material is cleaned off
This is the real melt pizzle
Old 01-09-2003, 01:28 PM
erbinone's Avatar
Great... I'm pulling it off today and gonna see what it looks like. Where can I get those metal gaskets??
Old 01-09-2003, 01:29 PM
kris's Avatar
kris kris is offline
Off playing with fire.
The dealer.
Old 01-09-2003, 01:48 PM
Originally posted by kris
The dealer.
Yup, Honda Parts Dept. should have it, or be able to order you some. But go ask around to make sure they fit, go to Honda-Tech.com and double check. I think pretty much all D-series gaskets are the same but you better check to be sure. I also know using one of these metal ones will change your compression so go find out which would would be better to use.
Old 01-09-2003, 08:53 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I would send it to a machine shop and have it pressure checked and resurfaced, probaly about $100. In your profile it says B16 if that what you have, a D series head gasket wont work...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 01-10-2003, 12:33 AM
gunnmen01
Yeah I never even looked at that, but then again he never said he was replacing the one on his own car did he?
Old 01-10-2003, 12:51 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
its a'ok to use a metal one for the d series... and yeah it'll bump you compression... but its very minimal.. but its still a gain...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 01-10-2003, 01:26 AM
habib_88's Avatar
habib_88 habib_88 is offline
Exclamation
just get a 92-95 gasket off a EX/Si. Thats your best bet, its metal of course. And the compression raise is small. The 88-91 1.6 motors run 9.1-1 and the 92-95 1.6 motors run 9.2-1....so you can see its not a whole lot hehe, but heck i'm doin it, the newer gaskets are a little stronger and more realible.
ForthGenHatch - I learned all of that off HT just passin it on hehe
89 Si #77 and now with 2003 STS winnAr mod!
LadyNRedSi: the integra is a spotless cow
habibswd: i'd sooooo milk a spotless cow
...wow that was a old conversation
Old 01-10-2003, 12:01 PM
erbinone's Avatar
I have a B16 in my 91 hatch. I just bought a 90 LX sedan cheap and want to get it running right, get it smogged, then throw a ZC in it. I think I'll just go w/ the cork gasket just to get by since I'm swapping it out anyways. I just need it to pass smog. Thanks for all the help.
Old 01-11-2003, 03:37 PM
erbinone's Avatar
Getting the head resurfaced this afternoon and going to put it back on. Now.... what's the best method to get that chocolate milk outta my motor??
Old 01-11-2003, 03:50 PM
kris's Avatar
Is the block still in the car?
Old 01-11-2003, 03:59 PM
erbinone's Avatar
Yeah... block is still in the car.
Old 01-11-2003, 04:04 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
take a straight edge and check to make sure your block isn't warped as well. put the straight edge diagonally across the block and check it out. i have my fingers crossed for ya.
did they happen to tell you how far the head was warped? that will give you an idea if the block warped much as well.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
