Old 01-09-2003, 10:57 AM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
How do you get paint out of door lines!
Hey i'm still stripping my 300ZX and most of its off, except a little bit inside the door lines, and panel frames... is there anywaya to get this "junk" out , without using a knife, and possibly scratching the car?
Also, i changed my order from hlj to
Carbon Fiber decal
matte black taimya spray
Bright Orange Tamiya spray
Tamiya Compound-
I have a question about this stuff. Can this stuff take off extra paint off clear coated car. Because i painted my Testarossa, then clear coated, and then painted door frames, but a little got onto the body.. will it rub out with tamiya compound? i used acrylic enamel
10 Mm masking tape
thats bout it
Old 01-09-2003, 11:00 AM
freakray freakray is offline
AF Modelrater
If you are using using a paint stripper to remove the paint, you could try to scrape it out using a toothpick, or you could get an old toothbrush and scrub it out if a paint remover like CSC has already softened it.
Ray
AF User Guidelines
Old 01-09-2003, 03:03 PM
AccordTypeR's Avatar
AccordTypeR AccordTypeR is offline
Send a message via AIM to AccordTypeR
Here is how to paint door line
Mix Tamiya X-1 and water
The ratio should be 7:3 (you can do 7:4 or wutever you want but paint should be more)
using sharpest brush just follow the line
let it dry for a min
using a q-tip with nail polish remover, just erase those black things that you've miss aimed
