Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-09-2003, 11:19 AM
t3t4c1hatch t3t4c1hatch is offline
Question turbo b18c1
does anyone know how fast aproximately in the 1/4 will a 92 dx hb with a b18c1 with a t3t4 pushing 15 lbs of boost??? thanx
Old 01-09-2003, 03:55 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
im predicting at least mid 14s to mid 13s, to run 15psi u need 2 alot of stuff to that b18c5 so thats why i give it only a md 13sec run at its best, this is only a guess! i could be wrong
1
Shift_BOOST
97 s14
Old 01-09-2003, 04:23 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
if you build your motor right and run at 15 psi youll be in the 12's no doubt, but you cant just slap a turbo on a gsr motor and boost up to 15 psi or you wont be riding around very long in that car
2002 Acura TL Type S
1991 Honda Crx Si
Old 01-10-2003, 07:42 AM
i plan on lowering the compressino to about 9.0-1
Old 01-10-2003, 12:07 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Oh, it will take more than that. That is a good start though. You are looking at a complete engine rebuild.
Old 01-13-2003, 12:42 PM
civicgsr_T4_60-1 civicgsr_T4_60-1 is offline
Send a message via AIM to civicgsr_T4_60-1
Ok, first off. On the gsr, with enough fuel and tunning, you will beable to run 15psi without building the motor. Something like hondata, haltech, aem ems, would be a good thing to buy. In a hatch, you should see mid to high 12's on street tires and low 12's maybe and 11 on slicks. There's alot that can be done to that motor. I run a gsr in my civic coupe. compression is 9.1:1 ran 13psi made 360hp and ran an 11.4 with the ecu kicking the rev limiter back to 6.5k rpm. This is on slicks and also using a T4 60-1 turbo vs. the smaller t3/t4. If you build the block, GE sleeves and bore it out some, with a bigger turbo, 10's won't be a problem.
00 civic with bolt-ons, i swear
Old 01-14-2003, 10:42 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Do you go by another name anywhere? Something like boostedb18 or somethin like that? Is that you or somebody else?
There's no replacement for displacement...No, not even a turbo.
Old 01-14-2003, 11:24 AM
Boostedb18 is a guy on Honda-Tech.com, i'm also on over there. I'm autoEXturbo over there.
Old 01-21-2003, 01:21 AM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
Shouldnt you do 14.2 in the hatch with only the gsr engine and good driving? If the car has a sunroof, take it out, you'll see a difference.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
