Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 01-08-2003, 02:51 AM
mad max 98 mad max 98 is offline
Arrow automatic drivers
hey guys, when u guys max out ur cars how does it go as far as shifting specialy from 3rd to 4th at what speed and rpm does it shiftand what happens if u put the od on if it is off
Old 01-08-2003, 11:08 AM
RALMADA RALMADA is offline
Remember that the rpm in which the transmission shifts depends on the throttle position and how fast you reach such position, I mean that if you go slowly to 3/4 of the throttle, it will change at lower RPM, if you place fast the throttle to the 3/4 position, it will maintain the gear until higher rpm , because the computer thinks you are trying to go faster (bypassing another car, etc.), not going in economy mode.
So to see if your over drive is working ( if the o/d light is not blinking and your check engine light is off, it must be working fine), go to at least 60 mph, with the gas pedal as light as you can, and press the o/d button, if the rpm change, your automatic transmission is working perfectly
Old 01-10-2003, 09:17 PM
y know when i reach 60mph od on or off doesn't make any difference what u think
Old 02-08-2003, 11:13 PM
Hammer Head Hammer Head is offline
od
sounds like your stuck in od.
Old 02-08-2003, 11:38 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
mine is stuck in od too, the lil button doesnt turn mine on or off anymore. ived asked on here a few times if any1 knew wat was wrong and how to fix it, but no one knos
Old 02-09-2003, 01:34 AM
Strider Negro's Avatar
Strider Negro Strider Negro is offline
Send a message via ICQ to Strider Negro Send a message via MSN to Strider Negro
sounds like u totally screwed the overdrive button. when I take it off my car goes in to a higher rpm and I literally ghost. When I put it back on the rpm goes down which makes me go faster before reaching the redline.
Old 02-09-2003, 02:07 PM
i dunno wats wrong with mine, it was like that when i bought the car. it did go out of OD one time, but i was dicking around and the car got stuck in 3rd gear, it would swtich on and off then. but i had to stop the car, turn if off and restart again for it to gear down
Old 01-25-2004, 10:30 PM
jboud8880 jboud8880 is offline
Re: automatic drivers
mine seems to be stuck in third gear also i was wondering what happened with yours?
Old 01-26-2004, 02:34 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: Re: automatic drivers
i don't think he has that car anymore. last time i spoke to him he had bought a nissan frontier and sold his max.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 01-27-2004, 02:46 PM
what type of frontier does he have?
is it the supercharged version?
that truck is cool!!!!
Old 01-27-2004, 05:12 PM
Maxxima_97 Maxxima_97 is offline
Send a message via Yahoo to Maxxima_97
when you race, do you take the O/D off? The engine revs about 1000 rpm's higher w/out O/D and feels alot more snappy obviously.
Old 01-28-2004, 10:39 AM
BP2K2Max's Avatar
no it isn S/C. last i heard he was actually trying to sell it.
BP's Rides;
Old 01-31-2004, 12:27 AM
Spaz Spaz is offline
Yes, when you race, race with the O/D off. It might be a good idea to powershift by running through the gear selector up until your redline (ie. have the shifter in first, around 6 throw it to second, etc..)
At the top of your third gear you should hit like 125 before you redline, that's when you pop your overdrive and hit that fourth gear.
Automatics suck. Heh. I've never liked mine.
Old 02-10-2004, 05:27 AM
Tyrexx's Avatar
Tyrexx Tyrexx is offline
Send a message via AIM to Tyrexx
I Have O/D off and just put it in 2 because 1st gear always has traction problems then when the car hits 6000RPM in 2 I push it up to drive. Only once have I redlined it 3rd gear but wait until 6000-6200RPM before turning O/D back on.
If you just leave O/D on it will got into 4th gear way to early, like 5700, this literally STOPS the climb or your MPH.
Keep it safe, only once have I ran it hard all the way up to 4th.
Old 02-11-2004, 01:02 AM
Ceasars Chariot Ceasars Chariot is offline
yeah, i thought so too !
97 Nissan Maxima (NA with USIM) - [email protected] mph
97 Nissan Pulsar SRV VZR (stock) - [email protected] mph
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
