Old 01-07-2003, 08:43 AM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
what engine can i swap?
What engine can I swap into my 91 crx dx automatic while keeping it an automatic, with the tranny that I already have?
Old 01-07-2003, 10:41 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
if you have a DX you can simply do the MPFI (multi port fuel injection) and get almost the same HP as a SI. you can also swap in either a sohc vtec 92-95 Si/EX or 96-00 Civic EX engine and use it with your tranny. the DX tranny sucks if you wanted to upgrade you could get an 88-91 EX (sedan) auto tranny
check out the engine section at www.4thGenerationCivic.com for links on how to do the sohc vtec swap
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-07-2003, 11:10 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
im swapping an auto b16 into my DX crx, ill tell ya how that goes.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-08-2003, 05:31 AM
Ami, would I need to replace my axles? And what sort of Vtec controller would I use?
Old 01-08-2003, 11:13 AM
amy@af's Avatar
nope. your axels should be good to go. there are 2 ways to activate vtec. the cheapest way is to get a 88-91 Si ECU (pm6) and distro. then you can get an rpm activated switch from Summit for $60. that way is cheap and easy however, i recommend doing it the other way. which is getting a p28 ecu (92-95 Si/EX) for $150. you can try and rewire 50 wires in your harness. or you can skip the head ache and get a conversion harness for $150. with that you only extend 8 wires and the rest is plug and play.
as i mentioned before...check out the engine section. all the links i found useful with my swap are posted there.
Old 04-14-2005, 06:12 AM
civicson234 civicson234 is offline
i have a 95 civic dx with the d15b7 engine and an automatic. im planning on swapping in a jdm b16 from a 93 civic SiR-II and am wondering if it will bolt up to the automatic transmission? THe same criteria applies above. All i want to do is drop in the engine. I just want to know if my axles are fine as is, will the engine go into an automatic. Also, im not sure if you are aware of this, but to the best of my knowledge the canadian built 92-95 civic hatchbacks came pre wired for v-tec, so am a right in assuming its a simple plug and play type thing? or is there more that im missing?
