Old 01-07-2003, 05:42 AM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
Unhappy Off topic but please help me :(
Okay, I have a 91 crx and my girlfriend has my old 94 sunbird. The sunbird's wipers are having problems and I wont let her drive the sunbird while its broken. This means she gets the crx untill i fix the problem... She's wrecked the crx before so please help FAST!
When I engage the wiper switch on the console I can hear the wiper motor trying to push the wipers, but the wipers wont move. If i get out of the car and nudge the wiper it will engage, however you have to help it the entire range, and it is choppy. Could something be loose? is the wiper motor failing? HELP!
Old 01-07-2003, 05:51 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
if you take off the wiper arms the splines may be damaged and so when the motor turns it doesn't grip the arm and the wipers will stay still but the motor will work
just a possibility
hope u sort it
cheerz
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 01-07-2003, 07:50 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yeah sounds like that to me also, if u can hear the motor going, then its the gears on the wiper arms are shot, so they need to be replaced.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-07-2003, 11:52 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
I know this sounds stupid but it could also be the bolts holding the wiper arms on ... someting to check, sometimes the littlest things are over looked.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 01-07-2003, 01:20 PM
1.5 liter 1.5 liter is offline
Send a message via Yahoo to 1.5 liter
lucky me my girl doesnt know how to drive stick
Old 01-07-2003, 01:30 PM
Skeme1's Avatar
Skeme1 Skeme1 is offline
just replace the motor.
or get her a bus pass :flash:
Old 01-07-2003, 01:49 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
It could be any of the things above...however, more likely it is the linkage that has failed. If the linkage has popped off or is loose, you will see symptoms similar to what you describe above. I had my wipers hanging on the drivers side mirror for a while
I dunno about crappy GMs, but on our Civics the motor is way over by the front corner of the pass. side windshield. - there are two linkage arms..one from the motor to the pass. wiper, and then another from the center wiper to the driver's wiper. The linkage (lightweight aluminum) is generally a simple curved/bent tube with holes in the end that are secured to the arms with stupid plastic buttons over a greased round nub. The plastic buttons crack and break with age then the linkage falls off.
I went to a junkyard and ripped the linkage off another Civic when mine failed and I got tired of trying to get the parts guy to understand the part I was looking for. With GM dealers as abundant as 7-11's, you may not experience the same difficulty as I did. If you aren't driving the car, disassemble that shit and take it with you to match up.
The Civic has lots of plastic shields covering all that shit up, and it is kinda hard to get to, but you should be able to figure it out once you expose the issue.
Good Luck - no wipers suck
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 01-08-2003, 05:28 AM
Thanks for all your help guys, It seems to actually be the linkage! next step is to replace it b4 the woman wrecks the crx again !
