Old 01-06-2003, 07:58 PM
Dallas_Fl Dallas_Fl is offline
Send a message via AIM to Dallas_Fl
What do I need
I'm doing a B16 swap and I need to know what I need?
B16 (engine, tranny, ecu)
Engine Mounts
shift linkage
wire harness
is there anything else that I need to complet the swap? I need to know becuae I am trying to figure out how much money it is actually gonna be.
Old 01-07-2003, 08:13 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
first off the cost varies depending on model of the car its going into.
im dropping the b16A1 (JDM CRX SIR) into my crx DX, but if you have an SI or HF it'll cost a lil less.
but my swap so far is costing me this,
$1500 for Engine, Tranny, ECU, Wire Harness, Shift Linkage, Axles
$250 For New Motor Mounts
$100 For new belts, hoses, plugs, wires, dizzy cap and rotor
and prolly another $100 for water pump, and various gaskets and stuff, which you may or may not need, but im changing the headers and intake manifold and stuff so i need to replace this.
so for me this swap is costing around $2000, but im doing all the work myself, if you bring it somewhere expect to be charged at least another $500-$1000 to put it in.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-07-2003, 09:02 AM
turbcivic's Avatar
turbcivic turbcivic is offline
Question on the swap. We had a 91 civic come into the shop that had a b16 transplant but i don't think the mounts were right. Both inboard cv boots had busted. The axels were at an angle to the engine is this normal
Engine
/ \ Sorry weak picture of what it looked like.
Old 01-07-2003, 11:39 AM
91zc 91zc is offline
Engine
Sounds like a custom cut and weld job to me. If not done right, the problems will never end.
91 civic 4dr
b16a
14.8@94
Old 01-07-2003, 12:02 PM
turbcivic's Avatar
Ya, a local shop did it and said that was the way it is supposed to look. I said bull and wanted your guys opions. Any body have any shots of a b16 looking up from underneath so i could so the shop?
Old 01-07-2003, 11:09 PM
crxlvr's Avatar
the axles should sit straight, usually when a shop tries to just modify stock mounts it causes those axles to bend and quickly fail, but if have a kit from Hasport or Place, the axles would be -- not /\
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-08-2003, 02:44 PM
turbcivic's Avatar
Thanks, i will tell the guy that and hope his car gets fixed soon.
What needs to be done to an SL for it to be a Twin Turbo? Topher9393 3000GT/Stealth 5 10-06-2003 02:58 PM
92-95 civic HB with JDM 94-01 headlight conversion. WHat need to be done? asnrefugee Exterior | bodykits | Lighting 5 11-11-2002 05:02 PM
whats needed for 97 civic to swap b18c jdm hatchman Engineering/ Technical 0 05-22-2002 07:00 PM
What needs to be done? civicx_xracer Forced Induction 1 02-04-2002 12:03 AM
