Hey,
Does anyone know how to program a keyless remote for a '98 Oldsmobile Intrigue. Part#10246215 Your help is greatly appreciated. Thanks, Ted |
Sit in the drivers seat and close all doors
press and hold the unlock button and insert and remove the key 3 times, on the 3rd time, leave the key in the ignition. press the lock & unlock buttons on the remote for 12 secs Repeat for ALL remotes ( up to 4) Remove the key for the ignition. This should program them for you.. |
thanks dude worked great. Damn dealers wanted $60 for 3 minutes or works. You saved the day. Thanks again...
I have a question. I have a remote from a 98 Intrigue. When I program it , the one remote I have for my 2000 Intrigue doesn't work anymore. They are the same make, #'s on the back are identical. Is there some kind of trick to get them to both work on the same car at the same time???
Are you programming both at the same time? That is, after you press & hold Lock & Unlock on one for 12 sec., do you do it for the other one as well? As a security feature, the car erases all remotes at the beginning of the programming process. That is so you can disable lost or stolen remotes.
Re: Keyless entry Remote Instructions
Thanks! my first visit here, and I found the info I was looking for in about 2 minutes. |
You press and hold both buttons down at the same time. Is this correct?
1996 oldsmobile keyless remote
I have a 96 olds cutlas ceirra remote that needs to be reprogrammed does the same procedure of using the key in and out 3 times work on this model as well?...or can someone let me know how to do this?..thanks
How can I find out if a remote will match my car? Does only the GM Part number need to match?
By the way, I have a 2000 Oldsmobile Intrigue GL |
Does anyone know if this is the same procedures for a 2001 intrigue?
Ok for some reason the procedure isn't working for me. I followed the instructions and tried several times. It hasn't disabled my first remote. Any other ideas or thoughts why it didn't work? The battery is good.
keyless remote
can someone please tll me how to program my new keless remote for my 2002 grand am gt,I already have one just need to program #2
thank You,Angie |
