Old 01-05-2003, 04:58 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
finally got it, need help
k after a long 9 months of waiting, i finally got my engine a b18a. but now i need to know a few things before i start. i picked it up from a friend of mine who crashed his crx, so the motor is from a crx si. i got the engine with teh mount adapters, but the rear mount was welded on to the crx so i cnat get it off, is there any other mount i can use, i thought i read somewhere about using the 90-93 integra rear mount, idk but looking at the rear mount, i see a rubber piece welded onto the car then a bracket bolted onto the engine, idk which piece is modifyed to mount the engine. the only thing i need help with is knowing what i need off the crx si to make the b18a work. i am gonna modify my dx harness and wire it up for multi point, but will my dx connectors fit on the b18a connectors ? i got the axles, and the shift linkage. i was curious abou the exhaust because the guy gave me a header with it and it bolted right up to the cat, so is no modicitaion required to the exhaust ? i also need to know will my stock throttle cable work ?, will my clutch cable work ? remember i got a dx. i also need to know what else i will need off that si, like will i need the fuel line from the fuel filter to the fuel rail, will i need any vaccum things.
so if any of you guys out there dropped a b16a or b18a into your dx, i really need your help in telling me every little thing you needed to modify on your car to make the b18a or b16a work. it normally wouldnt matter but the guy is gonna dump the car is a week, so i need everything off of the car now, i dont wanna miss anything.
i really appreciate your guys and girls help, thanks very much
Old 01-05-2003, 05:40 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
I say strip the hell outta his car and get everything just incase u need it, u never know, that way if ppl take awhile to post on here u got the stuff and if they say u dont need it then just sell it or w/e. i have never installed a B16a or B18a so i dunno about that stuff cuz i still got the stock D15B2 in my car lol, yay 93 hp:sun: but yea just strip his car just incase, and ask him if he can help u out with any ideas or ne thing, hope this is of some help
Old 01-05-2003, 07:27 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
The teg rear bracket you're talking about will only work with the rear mounts and not replace it. You need to get a rear bracket and any of the aftermarket mounts like HCP/Hasport or Place. To answer your Q's about the wiring, Yes, your connectors will fit but you need to add a few more wires to make it work (dpfi to mpfi). You'll need to replace your throttle cable, clutch cable, upper rad hose, distributor, ecu (pr4), axle & intemediate shaft (all from 91 teg). The only thing that you need from an Si are the injectors (non obd) and the injector resistor box which you will need for the dpfi to mpfi upgrade. Should you decide to add vtec to your B18a motor (lsvtec) or totally get a vtec motor, you only need to add 4 more wires from your original set up, 2nd O2, vtec solenoid, knock sensor, vtec oil pressure and of course a different ecu (pr3 or pwo)...Let me know, if you have any other Q's...
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 01-05-2003, 07:29 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
i agree, i would knab anything engine related......plus poke around for aftermarket parts :-D
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 01-06-2003, 02:59 AM
k i kinda got confused. is the rear mount modified at the bracket or the mount ? is there anyway i can use my stock civic rear mount because the one on the crashed crx is welded on, and i dont own any welding equipment so i cant get it off but i have the bracket on the b18a engine so yeah idk what to do or what will work. so my stock dx clutch cable will not work ? will the lower radiator hose fit ? what car do i get the upper hose for ? also what about the vaccum, will my dx have all the vaccum hoses needed to hook up the engine ? or will i need to add something for the vaccum hoses ? will my dx fuel line work on the b18a ?
i just need to know every single little thing i will need to change on my dx to get the engine runnin. my main concern is that rear mount and the vaccum lines, i guess wiring is alittle concern but i got the instruction on how to change my dx into an si.
Old 01-06-2003, 08:49 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
According to HASport, the rear bracket is from an Si-R or a 90-93 Integra...here is a link where I got that info from
http://www.hasport.com/Tech/Installs/EFB1.htm
HTH -
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 01-06-2003, 09:31 AM
EF_LSVtec's Avatar
vacuum hoses will work...upper and lower radiator hoses from 91 teg also. I may have old pics of my b18 motor that i can post so you can check it out. The bracket from the B18a motor will not work...you need to get the motor or car somehow to a welder and unweld the rear mount and replace it to work. You definitely need the 91 teg rear bracket...browse www.hasport.com and check it out, that site helped me a lot when I did my original swap.
AF Bay Area Crew
Retired SOLD 1/08
Old 01-06-2003, 04:32 PM
can i use my stock clutch cable ?
also does anyone know if i can unbolt the rear crossmemeber cause the rear mount is on the rear crossmember, so if i can take the whole crossmemeber off then i can get the rear mount, so does anyone know if i can unbotl that rear crossmember ?
Old 01-07-2003, 03:33 AM
any other info, i need all the info i can get.
oh and is there anyway to use your stock civc mounts because i am looking at the mounts he gave me and they look like my stock civic mounts. maybe even like welding the chassis brackets somewhere else, is that possible
