Old 01-05-2003, 12:04 PM
CivicSiR7's Avatar
CivicSiR7 CivicSiR7 is offline
Question TPS Sensor???
I had installed a B16A1 into a CRX Si. Everything is done and the only thing that's troubling about the swap is the TPS Sensor code. I tried everything from replacing to a different TPS sensor to checking the wiring and resetting the ECU and it stills throw that one code. Could I be doing something wrong?:smoka:
Old 01-05-2003, 03:05 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
try checking all 3 wires both at the tps and at the ecu one should be about 5 volts, one is a ground, and the other should range from .5 volts to 4.5 volts.... let me know if you need any more help...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
