Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-05-2003, 09:11 AM
Jared_80 Jared_80 is offline
Banned
4 cyl camry turbo?
I was hoping that someone here has some info on turbocharging a 4 cyl camry. I am thinking of buying a used eclipse turbo and fabracating an exaust manifold, but I have some questions. How well can a 2.2l handle 5-7 psi of boost, would I have to use water injection to prevent knocking, could the stock efi put enough fuel into the air (would I have to re-program it) , and are there any other factors that could prevent me from doing this? (aka coolong, automatic tranny....ect)
Old 01-06-2003, 01:38 PM
MaximusGTR's Avatar
MaximusGTR MaximusGTR is offline
Would be interesting, good luck!!!
"SHIFT_"
Old 05-10-2003, 12:44 AM
stratispho stratispho is offline
Send a message via AIM to stratispho
rather than re-asking the question thought i'd bump this one back to the top cuz i want to do the same thing...
FFF- Keep the rubber-side down
Old 05-10-2003, 01:11 AM
T-Tuning Customs T-Tuning Customs is offline
I have some in stok along with a few super chargers both of them fit the 5sFE found in the Camry from 92-01, email me and I'll give you the details.
Old 06-18-2003, 04:36 PM
toasted8x's Avatar
toasted8x toasted8x is offline
So... where can I get myself a supercharger for my Camry 94 for type of engine is 5sFE.
Old 06-23-2003, 07:02 PM
Kocho Kocho is offline
Do you have a web site?
Post this at the www.camryman.org or www.camryclub.org or www.toyotanation.com forums and you'll get a lot of responses...
As far as turbo for 5sfe, check out the above forums, plus these links:
http://www.poweredbytoyota.com
http://www.meisners.net/camry/
Also, RIPP Mods in NYC is already producing a bolt-on supercharger for the 4 cyl 97-01 Camry. Again, check out the above forums for more info...
Old 07-02-2003, 12:14 AM
chinoamigo chinoamigo is offline
http://trdnw.com/cat_turbo.html
http://www.poweredbytoyota.com/burie...ssfeturbo.html
same company, 2 diff sites. i've abandoned my turbo project because of it's cost.. the expenses just keep piling up..
Old 07-04-2003, 12:47 AM
camrized3 camrized3 is offline
Send a message via AIM to camrized3
camry turbo
this may not be what yer lokking for but i beleive most celicas have the same engine as camrys but aftermarket companies dont make products that say for camry any way look for celica turbos same engine evrything
and a turbo can be put on any car for the right price
Old 07-10-2003, 12:36 PM
mighty~mart mighty~mart is offline
Send a message via AIM to mighty~mart
hear any kits on the 2AZ-fe?
well this sounds great for those ppl w/ the 5s-fe~~!
mart
gen 5 camry SE
i4 DOHC
Injen intake
stock 16"
Old 07-10-2003, 07:33 PM
smokey8890's Avatar
smokey8890 smokey8890 is offline
do you have a 5s-fe? if so the mr2 3s-gte maifold will bolt right on. so far I got most of my parts but a few.
-supra n/a injectors
-mr2 map sensor
-hks ssqv
-mr2 mainfold
-toyota ct-26 dual entry
-oil line
-coolent line
-boost controller
-cat
-elbow
-j&s safeguard individual knock sensor
the only thing i'm missing is
-8:5:1 forged pistons
-pauter connecting rods
-air/fuel controller
-custom pipes
if you go to toyotanation.com or board.mr2faq.com you will find everything you need to know. like everyone suggested.
Old 07-25-2003, 09:52 AM
P-Ba P-Ba is offline
Send a message via AIM to P-Ba
NO......NO........NO.......NO!
For the turbo for the 5s-fe (ALL)http://www.poweredbytoyota.com/burie...ssfeturbo.html
For the supercharger for the 5s-fe http://rippmods.com/products/product...m&productId=82
I personally would prefer a Supercharger over a Turbo charger any given day. I don't know much about them, but I've heard 4 cyl cars can give off some nastey Turbo lag, as opposed to a s/c gives none.
Laugh all you want, your wifes car just smoked ya.
Old 07-25-2003, 10:43 AM
smokey8890's Avatar
my setup will have more power and alot less cost.
Old 07-25-2003, 11:56 AM
toasted8x's Avatar
SuperCharger Vs Turbo
SuperCharger Vs Turbo, can someone tell what is the difference and why each one is better is better for ther 5sfe engine.
Old 07-25-2003, 12:25 PM
smokey8890's Avatar
there are two ways to spin the fins to blow more aire into your compression chamber. supercharger use pulleys to spin the wheel. turbos use the exhaust gases. Supercharger has instant power. turbos takes alil more time to spool but will go beyond what a belt driven s/c. if your boosting low psi you should have much problem.
Old 07-29-2003, 07:35 PM
Toyrolla's Avatar
Toyrolla Toyrolla is offline
Send a message via AIM to Toyrolla Send a message via Yahoo to Toyrolla
Kocho, Smokey8890....whaassssuuppppp
Regards,
Nobody can break it better than me.
88 I4 Slushie, 89 I4 5Sp, 89 V6 5Sp, 82 Corolla, 72 510, 88 Minitruck.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
