Old 01-04-2003, 08:32 PM
crxhelp crxhelp is offline
Ls/vtec
I have a 1991 si and we are trying to install an ls/vtec engine we are wondering if the stock harnes from an SI crx can be modified to work with the ls/vtec or what do we need? if you can respond asap that will be great since we are working on it right now
thanks
Old 01-04-2003, 08:55 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
so you have a LSVtec engine and dont know how to properly install it? LSVtec is not a setup to toy around with, its actually very complicated and takes money and the right person to build it, you can't just take a b18a block and slap a vtec head on it and expect it to run correctly! You have to rebuild it and match it up the right way. Well, had to let that out, sorry, and i can't help ya with the wiring, cause i dont know.....
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 01-04-2003, 09:00 PM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
no you can not use your si wiring harness, if you have enough money to get an ls vtec setup why don't you break the bank a little and buy the wiring harness. and a ls/vtec is not anything to be taken lightly, the littlest thing will make it fuck up
Old 01-04-2003, 09:23 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
You can use your Si wiring harness but need to add wires for: 2nd O2, knock sensor, vtec solenoid etc...I'm assuming you're running your motor non obd and replaced your distributor with one from a 1st gen B16 and using either a PR3 or PWO ecu...
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
