Old 01-04-2003, 03:52 PM
Skeme1's Avatar
Skeme1 Skeme1 is offline
painting headlight corners (inside)
my friend just got black projectors for his rex and he wants to paint his headlight corners black in the inside.
i know someone has done this (CZ-R i think). i tried to do a search but didnt come up with anything. is there a how to for this?
thanks
Old 01-06-2003, 02:23 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I've done it, but it's a pain in the ass to get the lenses off of the housings without cracking them or melting the housings. I've tried 4 different times. One time it worked perfectly, but after painting them, I used hot glue to adhere the lenses back onto the housings, but the hot sun caused them to come off, and I haven't been able to do it correctly since then.
Anyways, the method I was using was taking a hot-air gun and heating up the edges of the lenses to warm up the glue that holds them on, and then pry them off with a screwdriver or putty knife. Like I said, only worked well on 1 occasion...
CZ-R told me that he had similar problems, so what he did was use a dremel tool with a cutting disc, and from the backside of the housing, cut all around the edge of the housing to remove it from the lense, then glued them back together. I thought about doing it, but it looks alot harder than it sounds...
Anyways, once you get it done, it looks sweet, so good luck.
Old 01-06-2003, 03:32 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Are we talking about corner lenses here? If so I can sell you mine which I tinted and ended up not liking.
Before
After
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 01-06-2003, 04:52 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
its so easy to take them apart i did both of mine in about an hour, i had then painted a sealed back together with black silicon
all i did is work a razor blade into the part by the headlight, once the hole was made i worked in a thin little pick and just kinda forced it to break the plastic weld
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 01-07-2003, 12:21 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
or you can buy em on ebay for $40 and keep your old ones in case you change your mind...:flash:
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 01-07-2003, 01:19 PM
Skeme1's Avatar
would the oven method work? ive heard its easier to open headlights this way. so far i have helped open 3 pairs of headlights (2 acura 1.6 el's and a 2001 mazda protege) and i also helped open a bumper lense off a friends 94 golf. I used a heat gun/hair dryer for the headlights and for the bumper light i used a pick and a hair dryer.
the golf bumper lense was my worst hack job i have ever done. although i did it on the first try, i know i can do better.
so i think i'll try the ol' heat gun technique with a flathead. if i mess up, it should be fine because my friend can gets another set of corners anytime.
i'll take pics of the finished product. (whether i mess it up or not)
thanks for the replies
Old 01-07-2003, 04:29 PM
ci5ic's Avatar
The oven method sucks. Tried that too... twice. Either it doesn't loosen the plastic weld enough, or it melts the housings or mounting arms and deforms them. I've found the heat-gun method to be the best, but still tricky to do without cracking the lenses...
If you've got an endless supply of lenses for cheap, then that's your best bet... good luck.
Old 01-08-2003, 12:43 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
i did the oven method and it worked perfectly but by the way, i lost that little plastic piece that the corner lense kinda threads into and i was wondering if by any chance any one has a hook up on getting one of those or some type of solution. i'd appreciate it!
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 01-08-2003, 02:13 AM
H4Bangin's Avatar
ill try to go to the junk yard for u tomorrow, i told u i would
Old 01-08-2003, 01:56 PM
mdnnccivicrcr mdnnccivicrcr is offline
I found some on eBay
90 Civic EX *RIP*
90 CRX DX *RIP*
88 Civic DX Sedan (pushing boost) *RIP*
95 Accord LX Sedan
Old 01-08-2003, 04:13 PM
Melt's Avatar
That would be sweet if ci5ic got some of those for his hatch
AF Bay Area Crew
Old 01-08-2003, 04:31 PM
ci5ic's Avatar
That would be hella tight, but unfortunately, they're for a CRX, so I'd need to mod my fenders and shit too.
Old 01-08-2003, 06:36 PM
Melt's Avatar
Im sure someone will make some for the HB soon .. but never for the 4dr
AF Bay Area Crew
Old 01-09-2003, 12:12 AM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
hey melt.....just to prove you wrong....here you go: http://cgi.ebay.com/ebaymotors/ws/eB...tem=1876641090
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 01-09-2003, 12:17 AM
ci5ic's Avatar
Holy shit!
If they're out there for the sedan, they've GOTTA be out there for the hatch. If anyone sees some on e-bay, PLEASE let me know. I would much rather pay for a set than fart around with those fucking lenses and a heat gun anymore.
