| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
hey everybody, i;m trying to lower my car with sprint 2" and i was gonna buy stillen camber kits 4 380$ when i have enough money , do i have to buy or should i just buy correction kit and where u get it from
can somebody help a brother maxima driver
You may not need any camber correction. Just make sure you pull plenty of positive camber when you put the lower strut bolts back in. Stillen camber kits are over kill for what you need. You can get camber bolts on the WWW for about 15 bucks to correct camber.
![]() 99 SE LIMITED - A few changes here and there but most of all SPOTLESS! |
camber kits just make it so the tires don't rub the wheel wells right?
hey bud , where can i get camber bolts for 15 bucks like u said:flash:
Ingalls Engineering has a wide range.
Camber bolts are used sometimes to correct camber after your suspension has been modified. If your tires are rubbing in your wheel wells, you have the wrong size/offset wheel & tire on your car or your to low.
that doesn't answer what camber is.
You asked camber kits just make it so the tires don't rub the wheel wells right? Which was answered with the word NO If you want to know what camber, caster, toe, thrust angel and so on is, try searching the www for information on front end alignments.
![]() 99 SE LIMITED - A few changes here and there but most of all SPOTLESS! Last edited by NJMAXSELTD; 01-13-2003 at 03:33 PM. |
