Go Back   Automotive Forums Car Chat > Mitsubishi > Lancer
Old 01-04-2003, 01:19 PM
Lil red '03 Lil red '03 is offline
Question Wheel hop
I've seen on evolutionm's site there is a DIY thing for fixing wheel hop by filling the motor mounts with windshield adhesive. I have heard about people doing this, but I want to know if anyone has actually tried it. Pro's, con's.....et al.
Just thought I'd ask.
Junior
Old 01-05-2003, 09:09 PM
HobieKopek HobieKopek is offline
Send a message via AIM to HobieKopek
Liquidlancer on em.net did his front mount and was satisfied. The rear is a bitch to get to and damn near impossible without a hoist.
Deyeme Racing also makes full replacement motor mounts for the Lancer with Urethane bushings if you want something that looks cleaning but costs a little more.
I swarm with the bees and diseases,
and even if your DJ was Jesus you could never f*ck with these kids.
Old 01-06-2003, 10:31 AM
Cool. are you talking about the neon mounts or the avenger / sebring mounts?
Junior
" XXX ain't got nothin' on me!!! ":finger:
Old 01-06-2003, 03:25 PM
No.
http://www.deyemeracing.com/products.asp
Search for Lancer.
2002-2003 Lancer DMRacing Drivetrain Mount, front with flexfirm filler
Get rid of that annoying wheel hop, and quit missing shifts, with our fiberglass-reinforced solid flexible polyurethane mounts. Not as harsh as hard plastic inserts, and better protection than DIY windshield urethane filled mounts. CS6AFMMxx
$69.00 / ea.
2002-2003 Lancer DMRacing Drivetrain Mount, rear with flexfirm filler
Get rid of that annoying wheel hop, and quit missing shifts, with our fiberglass-reinforced solid flexible polyurethane mounts. We do not use windshield urethane, which is not meant to cure thick, rather we use a high quality 2-part vulcanizing rubber that is used for prototyping high strength rubber parts. CS6ARMMxx
$69.00 / ea.
2002-2003 Lancer DMRacing Radiator Brackets with silvergoldredbluepurple bolts
Dress up your Lancer engine bay and shed a little weight with these brushed aluminum radiator brackets and anodized bolts. Less than 1/3 the weight of the stock brackets and bolts, and they look great too!
Old 01-07-2003, 02:02 AM
My bad, Hobie. I found 'em. I like the sound of those radiator brackets too. Might get me a pair when I get home. Thanks.
Junior
Old 01-07-2003, 09:20 AM
Yeah, they're nice. I've got a pair of the radiator brackets. They're not exactly gonna change much, but they're cheap and they look nice (and the get a lot less mushy under heat than the stock rubber ones).
Old 01-07-2003, 11:49 AM
So, what's your advice? Would you get flex ones, firm ones or one of each? Am I correct in believing that there are only two mounts? I forgot to look. I only had my car a week before I left.
Thanks.
Junior
" Be vewwy vewwy quiet, we're hunting bin laden. huhhuhhuhhuh. "
Old 01-07-2003, 01:11 PM
One front, one back. Good luck installing the rear mount on your own unless you have some knowledge of the install and a hoist. Front should be relatively easy.
I'd suggest flex, but not from experience. I just flipped a coin.
Old 01-07-2003, 10:33 PM
Thanks. Hope I have experience. I'm a mechanic and I've changed a few motors in my time.
:smoker2:
Junior
