Old 01-04-2003, 05:14 AM
Paperfish Paperfish is offline
Wire gauge
ok, what is the deal with speaker boxes coming with 16ga wire in them? Even the better boxes like Fusion. If I have to run 12ga from amp to box, why would anyone want 16ga from inside box to sub?
Old 01-05-2003, 06:38 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
shorter runs require smaller wires for the same power ..... besides, most of the power loss is incurred atr the connections.
P.S. have you bothered to look and see just how small the "tinsel" leads are that go from the speaker basket to the cone ?
Old 01-07-2003, 12:14 AM
un4gvnbb's Avatar
un4gvnbb un4gvnbb is offline
the amp also need much more power then it actually lets into the speekers. the thicker gage wire is made that way in order to handle the amount of amps it draws. once the signal is converted, the amprage drops significantly
Vrooom from the front and BOOM from the trunk
Old 01-07-2003, 09:06 PM
so is there even any advantage/disavantage in replacing the wire in the box to 12ga?
Old 01-07-2003, 09:13 PM
Audio Guy
probably not ... I would leave them alone
