Old 01-03-2003, 11:32 PM
Neige Neige is offline
WHY?!? WHY does this always happen!!
every time i spray paint a car, there are lots of little airbubbles everywhere, i spray it far away, in a dry area, shaked the can of paint up REALLY well, spray light coats and it STILL happens! this is seriously pissing me off
Current Projects:
[img]http://us.st2.yimg.com/store6.yimg.com/I/matrixcollectibles_1732_31118213
[/img]
Old 01-03-2003, 11:58 PM
935k3's Avatar
935k3 935k3 is offline
If you are using Tamiya sprays it is better to move the ball in the can in a circular motion to stir the paint than to shake it in all directions. Their paint has allot of pressure in the can and those bubbles are caused by the propellant in the can. Shaking the paint up seems to cause the paint to foam up in the can.here is a link concerning the use of their paints.
Using Tamiya Synthetic Laquers
Old 01-04-2003, 12:02 AM
hiver77's Avatar
hiver77 hiver77 is offline
and always warm the can first. Put it for a few minutes in a bath of warm water. Then shake, then spray.
That is my spraying ritual now.
Whenever I feel lazy and not warm it first the paint job is not good.
In the finishing stage:
Old 01-04-2003, 06:45 AM
Vagabond_se7en's Avatar
Vagabond_se7en Vagabond_se7en is offline
I second that, those little tamiya paint cans are superb if you prepare the cans well before painting. I try to use those cans as much as possible and for the rest I use the old airbrush.
Old 01-04-2003, 07:18 AM
God|Zilla168's Avatar
God|Zilla168 God|Zilla168 is offline
also clean the spray nossel after each use. This will prevent it from clogging up the nossel which sometimes is the cause of the splatters
Old 01-04-2003, 09:40 AM
phatmitsu's Avatar
phatmitsu phatmitsu is offline
Send a message via AIM to phatmitsu
Hey ASre you sure they are air bubbles?? Not fish eyes?? Do you wash you model before painting?After all my prep and finish work is done on the body (after primer and everything) just before getting ready to paint i use a cleaner made for real cars the cleaner removes oil and dirt but you can also wash dish soap (small amount) and water and rinse very well.. then only handle the model with lint free gloves on.. Paint is very fussy if there are any oils on the surface it will reek havic with the paint and it will look somewhat liek air bubbles.. Hope this helps ya somewhat.. Later Rick
Old 01-04-2003, 09:49 AM
supratuner's Avatar
did any one ever consider he is using testors?
if it is testors than no matter what u do this will happend but if u get tamiya and u wash it and primer it u have no worries.
i used tamiya for the first time in my life a week ago and ill never go back
Old 01-04-2003, 01:18 PM
phatmitsu's Avatar
Its not the testers paint.. I use testers my paint comes out great.. It dont matter how good your paint is if your doing something wrong its ganna look like crap.. I have seen models painted with 99 cent wally world spray bombs that are flawless and shine more then a mirror.. It all goes back to proper prep, proper spraying, and proper polishing.. Later Rick S..
Old 01-04-2003, 01:19 PM
hiver77's Avatar
Sorry, gotta to disagree here.
It all depends on the preparation. As long as you warm the Testor can first (a bit longer than Tamiya) the end result will look good.
OF course, Testor comes out in heavier spray and you have to take that into account.
Try spraying a Tamiya can straight from the cold storage and see what you get. Bubbles and peel. :silly2:
Old 01-04-2003, 01:53 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
I agree...it's all in the prep. My very 1st car wasn't preped at all - no washing, sanding, etc - and altho I used tamiya paint - it still came out horrid!!
Old 01-04-2003, 02:20 PM
ah i see the problem, cold can oh well guess i'll do better next time with all these info now. i didnt wash the body either hahaha
btw i'm using Tamiya, i expect nothing but tamiyas hahaha
Current Projects:
[/img]
Old 01-05-2003, 03:29 AM
hiver77's Avatar
You know, if it makes you feel any better, after preaching about doing prep-work in my previous thread this morning I got lazy and decided to spray clear-coat from a semi-cold can and in multiple coats to (at one sitting!!!). The result? Heavy orange peal...
And I mean seriously heavy peel...
Time to bring out the sand paper...
Old 01-05-2003, 05:48 AM
i wus painting the last 2 coats of my RX-7 FD3S today...and i wus using the techinques u guys posted, this time, i got a really glossy coat with minimal airbubbles and orange peels...but 2 factors fucked up the kit:
1) there are huge drops of paint on some parts (not very noticable)
2) the gray primer....the white tamiya just didnt cover all of it, i'd say it covered about 90%, i added like more then 3 layers, the panel lines are still gray-ish and u can hardly see them nemore....
wut i learned: well atleast now i got glossy body hahaha next model, dont paint anything white w/o a white original coat hahaha
Current Projects:
[/img]
Old 01-05-2003, 08:15 AM
hirofkd's Avatar
hirofkd hirofkd is offline
1) Possible cause of the problem is either the distance to the model was too close, or the nozzle was dirty. After paint is completely dry, use small piece of fine sand paper (1500 or above), and smooth it.
2) That's why both Gunze and Tamiya have white primer. Also, DupliColor has good white primer.
Hiroaki Fukuda
