Steering Wheel Alignment
I changed the pitman arm and idler arm on a 97 Yukon but now the steering wheel is off a few degrees when the front wheels are straight.
Am I correct in saying the pitman are will only go on the sector shaft in one position due to flats on the spline. Does anyone have a solutiion to align the steering wheel with the front wheels? Thanks |
Re: Steering Wheel Alignment
Due to wear this can happen and it requires resetting the toe to center the wheel, no other way.
So am I right saying the pitman arm can only go on in one position and you cant place the pitman a few spines in either direction on the shaft to correct the steering wheel position. |
