Old 01-03-2003, 09:53 PM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
Turbo Question
if i plan on runnning a 14b turbo at 6 to 10 psi will i need to upgrade my exhaust more. i have already upgraded to 2 1'4". or will that be fine for low boost like that.
Old 01-03-2003, 10:31 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Thumbs down
That's still a bit restrictive, but it's not a huge concern with low boost. You should still upgrade to 3" and that should get you a few more HP too.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 01-04-2003, 10:52 AM
91civicDXdude's Avatar
exhaust is not that important next to upgrading your fuel and internals. you can run about 6 psi on stock internals or so i've heard, but unless you upgrade your fuel by adding a 5th fuel injector or FMU, you will lean out at full boost. a lean running engine doesnt last long, so when your engine blows because of detonation, your exhaust piping will be the least of your worries
good luck, btw
Old 01-04-2003, 11:14 AM
i have a fuel pressure regulator but i am going to need upgraded fuel injectors right?? what would be right for this application? i want something that will just plug in with no modification or very little. and i need a fuel pump too right? which types are good? and would i need a intercooler if i am running low boost? and last but not least, lol what kinda of power do you think i will get out of this 14b turbo?? probally running 6-10 pounds??
Old 01-04-2003, 03:38 PM
Marc-OS's Avatar
This link should help you out with managing the boost: http://www.thedropshop.tv/vafc.htm
20 GOTO 10
RUN
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
