Old 01-03-2003, 03:07 AM
crj_lll crj_lll is offline
Send a message via AIM to crj_lll Send a message via MSN to crj_lll
Thermostat change resulting in electrical problem
I changed the thermostat on my 1986 CRX SI. Once I got the housing back on and everything hooked up properly, I tried to start the car and it did not start. I thought I broke the ground wire that hooks up directly to the housing. I replaced those wires and the cor will still not turn over. There is an electrical problem somewhere, but I am not sure where to look. Has anyone else had this problem? Does anyone have any ideas?
Old 01-04-2003, 01:15 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
did it even attempt to turn over? or is there a complete lack of power? do any of the other electrical components work? and check to make sure every thing is plugged in...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 01-04-2003, 01:45 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
how in the hell did you manage that?
2002 Acura TL Type S
1991 Honda Crx Si
Old 01-04-2003, 04:36 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
first make sure your wires are hooked up to your battery. you possible got coolant on an electricial item, which may have caused it to short out
Old 01-04-2003, 05:07 AM
Lightbulb Thanks
I kept going over and over my work and found the loose starter wire. I must have knocked it loose when I was done around there. I have big hands so that was the problem. Plugged that back in and everything works fine now. Thanks for your help, anyway.
