Old 01-02-2003, 12:56 AM
erbinone's Avatar
erbinone erbinone is offline
88-91 Civic SiR Cluster For Sale!
JDM 88-91 Civic SiR Cluster. I bought it but never installed it. Comes w/ wiring diagram. Not plug & play. Great condition, email me for pics. $200.00 OBO (Shipped Anywhere In The U.S.)
Contact: Roger [email protected] 562 743-5955
Old 01-02-2003, 01:07 AM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
I hope you find a buyer...but they only sell em for $125 plus shipping on ebay...good luck:flash:
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 01-02-2003, 01:39 AM
erbinone's Avatar
Thought I would start hi and see where it come down to.
Old 01-02-2003, 07:02 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
I'd love to get one of those some day. I gotta get the necessary shit done first though like my engine and suspension. Are they real hard to install?
Old 01-02-2003, 08:54 PM
EF_LSVtec's Avatar
Fairly easy...took me less than 3 hours using an ecu pin tool and some tape...I just downloaded the instructions on the internet so I wasnt really sure if it was accurate or not...I had to recheck my steps a couple of times and replace the VSS to an electronic one...Let me or us know when you're ready, I'll help you out.
AF Bay Area Crew
Retired SOLD 1/08
Old 11-11-2006, 09:00 AM
rey_civicdx rey_civicdx is offline
Re: 88-91 Civic SiR Cluster For Sale!
i need the color chart 4 a 91 crx cluster do u where i can find it
Old 11-11-2006, 02:38 PM
EF_LSVtec's Avatar
give me your email and I'll send you the instructions. I saved it on a "Word" document...online link probably gone by now.
AF Bay Area Crew
Retired SOLD 1/08
Old 11-11-2006, 02:39 PM
EF_LSVtec's Avatar
or try this...
The EF8 cluster connects by the use of four connectors. The three main dash connectors being a 6P,8P,and 10P along with a smaller 10P coloured connector(green or yellow) to wire in the little CR-X diagram in the corner (reminder light for open doors/hatch).
The USDM cluster wires in with the use of two connectors. There is one 12P and one 8P.
Here's how to wire it up:
Starting with the 6P connector (let's call it 'A'), as if the cluster were sitting in the car plugged in, from the farmost USDM Passenger side terminal.
Location Colour Function USDM HF Wiring location
A1 Grn/Red Ebrake Indicator C710 #5
A2 Blu/Red A wire is there but does nothing on instrument cluster
A3 Yel/Grn Water Temp. gauge C709 #10
A4 Yel/Wht Fuel Level gauge C709 #11
A5 Grn/Wht Low Fuel Indicator
Wire must be run from fuel tank after installing a'90-3 Integra fuel level sensor in the tank.
A6 Blk Ground
Connector B (8P in top center of cluster)
B1 Yel/Red Speed Sensor Signal
B16 on 4G SiR ECU C709 #9
B2 Grn/Yel Right Turn Indicator C710 #1
B3 Blk Ground
Need to either ground out to a steering column mounting bolt, or splice into the same ground wire you used in connector A, as the USDM cluster only uses one ground wire
B4 Red/Blu High Beam Indicator C710 #3
B5 Wht/Blu Low Voltage Indicator C709 #3
B6 Blk/Yel Switched Power to Cluster C709 #4
B7 Blu/Yel Unconfirmed for the moment
Stay Tuned!
B8 Grn/Blu Left Turn Indicator C709 #12
Connector C (10P tach side of cluster)
C1 Grn/Org Check Engine Indicator C709 #8
C2 Yel/Red Oil Level/Pressure Indicator C710 #7
C3 Yel Switched Power to Cluster
C4 vacant
C5 vacant
C6 vacant
C7 Blu Tach Signal C709 #2
C8 Grn/Blu vacant
C9 Red/Blk Dash Lighting C709 #7
C10 Red Dash Lighting C709 #6
Connector D (small connector that powers the CR-X drawing for doors/hatch open)
AF Bay Area Crew
Retired SOLD 1/08
Old 11-11-2006, 02:57 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
hey noob! WHY THE HELL DIDN'T YOU JUST MAKE YOUR OWN POST INSTEAD OF BRING THIS ONE BACK FROM THE DEAD?
-tony-
2000 honda s2000
CRX SiR Cluster for sale still.. 91civicDXdude Classifieds 2 12-20-2004 01:35 PM
JDM 88-91 Civic SiR Cluster For Sale erbinone Engineering/ Technical 3 01-20-2003 08:25 PM
JDM 88-91 one-piece headlights for sale Payneth '88 - '91 Civic | CRX | Wagon | Shuttlee 1 12-02-2002 07:42 AM
